Twin Pedal Mod B1550
100inchhammer
B1550, 54" Deck
Feb 28, 2016
38
Lake Milton, Ohio
I am currently finishing up my twin pedal mod. I am leaving the treadle pedal as it is, but adding a 2nd reverse pedal beside the forward pedal. I'll post pics soon.
Sent from my SAMSUNG-SM-G891A using Tapatalk
G.rid
L48 tlb, ssqa forks, manual thumb for hoe
Aug 19, 2016
207
17
Oxford, NS, Canada
That I'd like to see!
I've had my L48 for 6 months now and still haven't quite got the hang of the rocker style HST peddle. Also, holding in reverse with my heel while clearing snow gets old fast.
Looking forward to pictures.
100inchhammer
B1550, 54" Deck
Feb 28, 2016
38
Lake Milton, Ohio
I think you'll like the finished product. I only have 2 small parts to make, tap some holes and weld it up. Then I'll install it and make sure clearances are ok, then I'll have some finish product pics. Here are some in progress pics for now.
G.rid
Aug 19, 2016
207
17
Oxford, NS, Canada
Looking good so far. Not sure I understand how it will work yet, but I'm sure it will all make sense when it's on and hooked up.
You gotta love water jet! Clean, precise, and no grinding to deburr the edges.
100inchhammer
B1550, 54" Deck
Feb 28, 2016
38
Lake Milton, Ohio
Ty. I'm finishing the last part now, already got some tacked up. I'll actually mount and operate it without the floorboard at first, then add the floorboard to check clearances, so you'll get to see it function without the floorboard in place.
100inchhammer
B1550, 54" Deck
Feb 28, 2016
38
Lake Milton, Ohio
I had to take a break from working on it as I tore my meniscus in my knee shortly after starting this. My original pedal arm had significant interference with the brake pedals. I made a new arm from sheet metal so I could adjust it to fit, this was finished today. The pedal arm needs fabricated yet from my template them it will be finished. I have to cut some clearance in the floor board for the linkage yet. Everything else is fitting together very well. When you see today's pics envision the pedal arm operating together with the linkage you see.
Yooper
3901 LA525
May 31, 2015
1,602
725
NE Wisconsin
Excellent workmanship! I like it! Looking forward to seeing the installation.
100inchhammer
B1550, 54" Deck
Feb 28, 2016
38
Lake Milton, Ohio
I have video but I can't upload it. It works just like I hoped. Now I can operate both directions with my ball of my foot instead of my heel for reverse.
8,259
Load the video to You Tube, then put a link to it on here. ;)
I have to admit, when you first posted I was very skeptical that it would even work, and if it did it would look like it was butchered up!
I was totally wrong on that, you did an excellent fab job! :cool:
armylifer
Mar 26, 2013
2,101
851
Thurston County, WA
That is really cool. That mod is one of the best I have seen.
