Tie down points
KbotaL185DT
Kubota L185DT (sold),Kubota B7800, LA402, 5 foot Bush Hog Squealer
May 29, 2020
19
27
Rangeley, Maine
Built these tie down hooks for trailering. Just used a thick wall angle iron and angled the edges.
KbotaL185DT
May 29, 2020
19
27
Rangeley, Maine
Do you use a slip hook then or a clevis?
I use 4 10,000 lbs double hook ratchet straps on the tractor. Then I have two 1.5 inch 3000 lbs sex straps I use to secure the attached implements.
FTG-05
Jul 21, 2013
290
135
TN
Tell me more about the sex straps, please!
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
544
308
Mandeville Louisiana
The brackets will hold, my only comment is the two bolts holding the bracket are shorter by the thickness of the angle iron and not using the full depth of the threaded hole. Just my .02
