I am asking if this set up appears to be correct and if not, how might I go about changing the gap between the deck and the stoppers. Also it seems to me the gap is largely controlled by the cutting height you set the mower at (at least in when in the down position).
This is an RCK54-24B deck on a B7300 with the cutting height set to 3.5 inches. Left side, deck in "down" position.
Pic 1: Front link. The pins ride just back of the front of the slot. Does this appear to be correct? There is little movement deck up or down, seems to make no difference.
Pic 2: Front stop, 1.75 inch gap.
Pic 3: Rear stop, 1 inch gap. Is the stop link show in the picture used to pin the deck in the up position using the hole in the deck tab?
For pics of the some stops in the up position see next post.
