RCK60-30BA mower blades.
Rob 80
B2650 HSD
May 9, 2016
39
WVA
My belly mower is model RCK60-30BA the manual list RCK60-30B and RC72-30B. I guess they use the same parts.
I'm looking for the mower blades and the main belt part numbers. My belt is fine just want one on hand not sure how long they last local dealer said it was $124 :eek:
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,369
1,572
Near Lancaster, PA, USA
I'd check the parts diagram before assuming which parts may be common between the two decks. Manuals sometimes list different models that have operational similarities but different parts. My guess is the two decks don't share blades or belts.
I've had good luck with a site called vbelts4less.com in the past. Go for a kevlar belt if you can.
Rob 80
B2650 HSD
May 9, 2016
39
WVA
I can not find a parts diagram for a RCK60-30BA only the RCK60-30B.
Yeah i'm sure the 72" model uses different parts.
SDT
multiple and various
Apr 15, 2018
3,266
1,062
SE, IN
FWIW: I changed the double V belt on the MMM on my 1994 B1750HST after 17 years when a spindle bearing failed. The belt was still good at the time and I kept it for a spare.
They last a long, long time if you keep grease and oil from them.
SDT
