Need to get some wires pulled into cab of MX6000
davemc
Kubota MX6000
Jan 9, 2022
9
I need to get some wires pulled into cab of my MX6000. It is wires inside a plastic conduit that is about 1/2" in diameter. I might be able to get them in between the back window and the rubber seal, but that is not ideal. There is an access hole to the cab below the window that is plugged with solid round rubber disk. It is probably 2.5 inches in diameter, but have not measured it. There is another access hole to the right of that, which has a rubber grommet, but has wires already running through it and not enough room to bring in the conduit.
Is the solid round rubber disk designed for cab access? Can it be replaced with something that has a hole in it to accomadate the wires in the conduit? Or maybe just cut a hole in it to allow the wires to be pulled thru? Any idea what the rubber disk is called?
kubotafreak
Sep 20, 2018
1,049
394
Arkansas, US
Yes the factory kit instructs you to cut an x in that plug. I bought an additional round grommet when I ran mine. Made it look cleaner.
