M9000 exaughst pipe
Ikc1990
Kubota m125x, m9000, b2710, and other equiptment
Dec 2, 2020
292
130
Vermont
So I have a m9000 the exaughst pipe is curved but the end is crunched a bit from previous owner damaged. But I can put rope down and fit in my shed but with the exaughst pipe do tall I can't. I would like to cut 6 inches off and put just an ol d style flapper on it. What is best way to cut? To keep from metal filings getting down it? Best if I removed it?
4,551
With an exhaust pipe cutter like this: https://www.harborfreight.com/exhau...MI7Lzj8a7M-gIVGxbUAR2WxwdREAQYAiABEgLQn_D_BwE
No filings. Minimal stress on the pipe. No need to remove from the tractor.
If you can spin it 360 degrees a single wheel pipe cutter would also work.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
526
Benton City, WA
I had a Mitsubishi tractor and the exhaust went straight up. I worried about water getting into the exhaust but upon inspection they had worked out a solution. There was a hole at the bottom of the pipe where it made the ninety degree bend to connect to the manifold.
3,322
Don’t rely on that drain-hole in a rainstorm. It’s designed more for condensation-cycling overnight…not for real water intrusion. During storage, put an old tin-can over the end of the pipe is a cheap solution.
(Failing to prevent rain or water from getting/draining down into your exhaust is a good way to lose a diesel engine. Water will get into the manifold…enter a cylinder via an open exhaust-valve….and create a hydraulic-lock for that next compression-stroke (likely on engine start) and result in a blown piston or bent/broken connecting-rod.)
