Landscape Rake Size
sula bob
2005 L3830 with back hoe, FEL with grapple
Apr 16, 2015
35
Samsula, Fl
As long as it doesn't weigh more than your 3 point can lift you should be fine. According to tractordata.com the lifting capacity is 400 pounds. Just don't try to dig in too deep. If it's too much take a torch and cut it down. I've got a 6 foot for my L3830.
Piker
2012 Kubota 2320, 2002 Honda Rubicon
Dec 1, 2010
164
Riverview, NB, Canada
Owners manual for my 1980 B7100 stated 400kg not lbs. I used a 450 lb brush hog & it lifted it easily. Also had a 50" rear blower, worked great.
6,319
6' rake will work fine on a B7100. You're just dragging it on the ground, and picking it up once in a while.
dobiedisco
B7100 4wd (sold, seller's remorse), BX2200
Sep 7, 2015
46
Fort Smith, AR
Thanks for the responses, I figured I could use it for the scooping, but thought I'd check with the experts! I saw the 400 lb capacity on tractordata, too, and thought this really is a big step down from my MF135. It came with a 4' boxblade w/teeth and that's what I'll use for maintaining the driveway and do a little work to help the folks at the stable I'm currently boarding at.
hitechredneck
L2501, Land Pride Rotary Cutter, Woods tiller, FEL, Dirt Dog box scraper
Sep 21, 2015
26
Belton, SC
:confused: I have a little B7100 and wondered if a 6' rake would be too large for using to scoop horse poop?
My young son was reading over my shoulder and exclaimed, "A 6 foot rake?! That'd be more for elephant poop!"
I got a chuckle out of that and thought I'd share.
comfun1
b7100 with 1630c loader
Jul 28, 2015
46
Independence
The landscape rake is one of the lightest implements I have. I have a six footer that I use behind my b7100 and it is no problem. It is a very handy attachment. When I am cutting and burning trees and brush I use it to snag limbs and drag them to the burn pile. It will catch two to three inch limbs. Sometimes I run the tiller over an area and then the landscape rake. The six foot width cuts down the high spots and fills in the low better that the box blade. Another use I have found is grading gravel drives. It's a great tool with lots of uses. When I first bought it, I was afraid the tines would break. I have bent a few but never broken any.
dobiedisco
Sep 7, 2015
46
Fort Smith, AR
That's good to hear you have the same tractor and no problems with the rake. I'm trying to get used to this smaller tractor and my fear I'm going to break something on it!
