L3800 Tie rod removal
DaveMueller
L3800HST TLB, LA524, BH77, Ford 917L
Apr 16, 2019
24
Mill Run
The grease fittings in my outer tie rod ends were both broken off by the PO. It looks like it will be easier to deal with this on the bench vs sitting on the garage floor. I'm assuming it will be comparable to removing a tie rod on a car which I have the tools for.
Any idea on thread size? I think the threads are different on the tractor vs the implements (LA524 and BH77).
Thanks
Dave
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,253
1,035
Williamstown Ontario Canada
Before going to the work of removing the tie rod assembly, try lightly driving a small flat screwdriver into the hole of the Zerk.
Then turn the screwdriver with vice grips.
Zerks are rarely rusted and often come out easily since they are greased regularly.
Dave
Pau7220
Aug 1, 2017
785
279
Scranton, PA
If you have one of these in your toolbox the easy-out is built right in for broken fittings.
Luckystars
M5950 M1840A RTV900 CLUB CAR CARRY ALL 1
Mar 1, 2018
98
Webster FL USA
Thanks
Dave
If you have a torx set of sockets you can find one that will snuggly tap into the center hole. The 6 points of the torx star are the best easy out. You shouldn't be under the tractor 5 minutes. As for the thread size I'd just have the Harbor Freight assortment kit handy.
DaveMueller
Apr 16, 2019
24
Mill Run
I was able to get both out with a new set of ez outs. Luckily, they had the drill sizes etched on them and I had the proper size, and it was sharp to boot! The fittings were harder than I expected.
Thanks
Dave
