A few years ago, one the plastics suppliers that I dealt with for years stopped selling to the public, and the other went out of business.
I needed some colored plastics for a few upcoming jobs, so i thought I would try recycling HDPE. (High Density Poly Ethylene)
I take no credit for the process- there are lots of youtoob vids showing how to do it. Start by watching some of those. But I thought I'd show what has worked (and not worked) for me. This process is labor intensive, so it may not be right for everyone.
First, you need an oven. I use a couple of garage sale toaster ovens; larger means larger molds, larger batches.
You can use one, but two works better, one to heat the plastic, one to heat the mold.
I don't recommend the kitchen oven, (PO'ed wife) heating will produce whatever smell the contents of the bottle held.
You will need a good supply of parchment paper, (the kind for cooking) this plastic sticks to just about everything but parchment paper.
Some high heat gloves are essential, and a hydraulic press. Mine is 12 ton.
An infrared heat gun is handy, but not essential.
Use only CLEAN #2 plastics, from laundry detergent, antifreeze, cleaning agents, shampoo, body wash, milk & orange juice jugs, etc.
Avoid like the plague anything that contained oil- motor oil, hydraulic oil, gear oil, and the like. No matter how hard you clean, you cannot get the oil residue out, and it will leach out during heating, ruining the whole batch of the plastic. Don't ask me how I know this.
I also avoid any harsh chemicals. (weed killer, bug killer, etc)
Cut the CLEAN, DRY bottles into pieces; about one inch seems to be a good compromise, larger is harder to heat & get rid of air voids, smaller works better, is more homogenous & less trapped air, but is way more labor intensive.
I use a utility knife & LARGE sheet metal snips. Now that I have a sheet metal shear, I will use that.
I initially used wood molds like most youtoob vids, but found they produced too much waste- voids, poor fill in in the corners, lots of warping. (but a good starting point)
I then tried aluminum cans with wood top plates, better because you can heat the can, but still not great.
Molds I machined work the best, they can be heated, and then the plastic can be squished in the hydraulic press.
Caution- PLASTIC & MOLDS & OVEN ARE HOT!
