grinding gears
slickwilly1976
L1500,L1500dt, B2920,bush hog,tiller,scrape blade,cub lo-boy
Jul 14, 2013
Rocky face Ga
I jumped on my 1500dt today and when I changed gears they started grinding bad. Ive never had this problem before. Any thoughts?
gpreuss
Oct 9, 2011
1,166
Spokane, WA
I'd check the clutch linkage and transmission fluid level.
kc8fbl
2014 L3200 HST FEL, 1949 Minneapolis-Moline R
Aug 23, 2012
222
Gobles, MI
Was it all the way in gear before you let out on the clutch? I've had it sometimes when it doesn't go all the way in. :rolleyes:
kubotasam
Apr 26, 2010
1,208
130
Alfred Maine
It is possible you clutch is stuck or starting to stick. If the tractor sat for a while between uses and especially if it sits outside, the friction disc on the clutch can rust to the flywheel causing the gears to grind. If you can get the transmission into a gear and have the engine running with the clutch pedal pushed down run it this way for a few minutes. This will help to clean the rust and could clear your problem.
If you just ran the tractor a few days ago, and/or it sits in a covered storage this is not your problem.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Like Sam said. Sounds like the clutch is frozen. When new, it came with a block of wood to jam the clutch open if you were going to leave it stand for a month or more. The newer ones have a latch pin that will lock the clutch open, same idea. I'd get it in the gear that will send it out of the lean-to while it is off, push in the clutch, and try to start it. The starter may have enough juice to break it loose.
slickwilly1976
Jul 14, 2013
Rocky face Ga
I got it out and used it today but the gears are still grinding. Some times they slide right in and other not they grind bad
:confused:
