clutch replace l2350dt
nitrah
l2350dt
Mar 3, 2017
acampo ca
i saw on utube a video showing splitting tractor. they had a set of wheels attatch to a pipe bolted to crankcase. would like to know i anyone knows where to find these. dealer quoted $5000 to replace clutch, tractor is only worth 2, so i need to do it myself.
5,394
You won't be able to buy it, you'll need to make them if you want that to help you split the tractor.
4,910
1,636
Kubota might offer some splitting stands as a special tool. I'll have to look at my old literature to see if there is a price and/or if they're available or not. They were simple in design. Just a couple square plates, 2 of which were the tops, about 14" square, then the bottom plates, which were a little wider, with wheels. In between the top and bottom were 4 legs made of tubing, each leg had a sliding setup where a large od tube fit over a smaller one, so that the top platform would be able to raise or lower with a hydraulic bottle jack. Slick setup and I should probably make a set. Problem is, I might have a Kubota in the shop one day, the next day a Ford, the next day a MF....and DIY stands/dollies may not fit all of them, and that would upset me to spend a bunch of time on dollies and them not work.
5thGenTexan
L3130
Aug 20, 2015
10
Van Alstyne, TX
They quoted how much??
I needed a new clutch in my L3130. I went and pulled the invoice, it was $1885 and they also did the front end seals.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
577
179
Herald Calif.
Hello
I am in your back yard almost. Send me a PM and and can help you with you clutch problem.
Thank You Lance
1970cs
1,124
Grand Ledge
Quote is way to high! Mid to high teens sounds about right for parts and labor.
It's small L series. 6x10 block of wood and bottle jack and chock the front tires and wedge wood blocks between the frame rails and front axle. Use a full size floor jack and roll the back half away. This besides electrical, steering, linkages, propeller shaft (fwa) and hydraulics disconnections.
Pat
rbargeron
Jul 6, 2015
1,155
226
western ma
Pat
Agree completely - the halves of a L2350 aren't very heavy - fancy supports are simply not needed. Block up one half on a metal milk crate etc. and roll the other away on a floorjack. A piece of plywood will do under the jack if there isn't a hard floor. Whoever quoted 5k is just a crook.
4,517
What these guys have said is right on. Take your time, take pictures of each thing you remove, ask questions, as you remove hardware put it in containers to identify where you removed it form, and you'll do just fine.
5,394
Oh and if your going to do the work yourself, send me a PM and I'll forward on the WSM (AKA service manual) to help you with the repair. ;)
hollettster
Kuboto L2350
May 16, 2024
Lancaster OH
Hello, I have to do the same job on my L2350. Do you have that service manual still? Is there a good part number for the whole kit? Almost looks like there may be 2 different sizes?
5,394
5,394
