BT1000 Backhoe
Charl723
Kubota L45
Nov 26, 2023
Stella11122012$
So I posted a week ago looking to find a BT1000 backhoe. I’ve found one. Issue is it’s on an L39. I have a L45. I assumed BT1000 would be an exact fit from an L39 to a L45. Am I correct or wrong? I have the gentleman measuring the spacing between the upper pins, lower nubs, and height between pins and nubs. Can anyone confirm it’s the exact same backhoe? Thanks for any help.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,060
Williamstown Ontario Canada
From memory there have been cautions on this forum about certain tractors not tolerating a 3 pt hitch BH. Owners end up with a cracked rear housing. This may not apply to your model!!!
I suggest you read thru this thread and even contact rbargeron who is both engineering educated and knowledgeable about tractors about when a rear sub frame is recommended.
rbargeron BH
Try searching for posts by North Idaho Wolfman aka (NIW) about 3 pt backhoes
Dave
notforhire
Kubota L47
Dec 5, 2019
148
69
Meadows of Dan VA.
rbargeron BH
Dave
I believe the OP has a tractor from Kubota's commercial line that doesn't utilize a 3 pt hitch backhoe.
I would think that a Kubota dealer should be able to answer his question.
Looking at Tractor data, I think a L39 uses a BT1000 and a L45 uses a BT1000a.
My L47 has a BT1000b backhoe.
Maybe you can find out what, if any, changes exist between a BT1000 and a BT1000a.
5,188
rbargeron BH
Dave
The B1000 backhoe is the FACTORY MATCH for the L39, and is absolutely NOT a 3pt backhoe!
The B1000 is for subframe mounting ONLY, and is the factory BH for both the l39 and L45.
Check Tractordata.com
5,188
My L47 has a BT100b backhoe.
I think you missed a zero there.....
Your L47 should have a BT1000b backhoe.
Afarley
Cat 306, Cat 279D3, Cat 312EL, Kubota L39, Kubota Bx23s
Dec 13, 2025
NC
I have a BT1000 backhoe id sale or possibly trade if anyone is still looking.
Im also in search of a L39 parts tractor.
