B bdale Member Jul 24, 2016 47 1 8 N.C. Oct 3, 2017 #1 Any one have a part No. for some good blades for a B2650 with a 60 inch MMM.
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 10,917 2,737 113 Bedford - VA Oct 3, 2017 #2 bdale said: Any one have a part No. for some good blades for a B2650 with a 60 inch MMM. Click to expand... this is typical: http://www.baileysonline.com/Landsc...ubota-Mowers-RCK60-27B-RCK60-24B-RC60B-21.axd do not let the print fool you........... these have 1 1/8" center hole. These are the number you need to "look over" Blade Length 20-1/2" (52.07cm) Blade Width 2-1/2" (6.35cm) Blade Thickness .250" (6.35mm) Blade Offset 1/2" (12mm) Blade Lift Height 1" (25.4mm) Center Hole Diameter 1-1/8" (29mm) sometimes the top one will be 20 9/16 .....not to worry, those two will work fine more: https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias=aps&field-keywords=K5371-99040
