B3030 Keeping tires from Dryrot?
newbiewankubotie
B3030 20
Dec 23, 2015
25
Tyrone PA USA
Hi just asking a simple question, just bought a b3030 2010 Kubota--want to know if there is a tire treatment to prevent dry rot..back tires are like new--but worried about rot? Spray? something to put on them beside armour all?
Kanook
Kubota B2650HSDC Kubota RTV900
Jun 29, 2015
32
Almonte, Ontario
My B1700 was 18 years old when I recently traded it in on a B2650 cab tractor. The tires were all original and dry rot was never an issue and the only tire issue was a slow leak caused by a puncture. It was always parked under cover. The tires on my Mustang are 14 years old but they get a work over with Maguires tire stuff a couple of time a year.
2,959
Here's a post from another thread by a guy (Tiredguy, Al) that I really respect for his knowledge about tires:
http://www.orangetractortalks.com/forums/showthread.php?t=22832&page=2
Tallbald,
avoid pressure washing the tires it's very easy to damage one and NEVER
use Armor All on any tire EVER it actually causes them to crack more over
time.
Can't guess the price without knowing the sizes but if it's been kept out of the sun and the cracks appear to be minor I wouldn't be in a hurry to replace them. Actually tubes are more common the larger that tires become and I
wouldn't tube them unless there's some minor problem best determined by
an experienced tire dealer. As suggested windshield fluid or a mixture of
diluted dish soap and water in a spray bottle will show you where the leaks are if they're losing any air. Extremely deep cracks showing cord do need to be replaced as they can be dangerous if they blow out when someone is near, quickly escaping air causes dirt and objects around it to hurl through the air possibly hitting someone maybe losing an eye.
Wear safety glasses and use an air pistol to break loose dirt in places the brush won't reach and it works well around grease zerks too getting the dried grease and gunk off before using the pressure washer it will speed up the job using less water which you don't want to get inside anything. A large flat bladed screwdriver in hand to poke and prod helps too while blowing off the caked on dirt.
Good luck and have fun bringing it back to a shining star.
Al
