B2650 break in
Rookie Farmer
B2650 SSQD forks 60" rear finish mower
Jun 9, 2017
Tenino, WA
New to the forum and tractors. Just took delivery on a new 2650. I know from previous adventures there are differing thoughts on the best way to break in an engine. It was the one question I forgot ask during the delivery tonight. I am in the process of reading the book also.
It is going to be used on 5 acres of flat ground that is 95% pasture. Our property is 214' x1056' so it doesn't take long to travel the entire length.
Very impressed by the 60" finish mower, breezed right through a test patch that 12-18" tall and soaking wet as it was the typical PNW spring weather today. Wait 10 minutes and it will change.
Thanks
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
I'm an 89 year old graduate engineer: I've seen these warnings and advice for all sorts of equipment. Yet, I have never seen any documentation that "giving it hell" ever caused any problem. My theory, if it can't be run like I want to, I don't want ti.
6,378
Good advice thus far.
Moral - don't go Balls to the Wall, but use it for its intended purpose.
Enjoy - I'm jealous! So many times I wish I had a tractor just a little bigger!:p:p
3,764
Run it like you stole it,,, ya got 3 years if she goes south, but to be honest they are designed to run hard out of the box,,,, vary the RPMs up and down then give it hell
MikeyA
2016 B2650 FEL and 60"mmm,1998 B2400 MMM FEL(sold!) BB 4ft BRUSH HOG
Mar 6, 2010
150
West Central Illinois
I kept mine below 2100rpm for the first 50 hrs....the bright side is, this motor makes plenty of torque and I still rarely go above 2100 rpm!!
Rookie Farmer
Jun 9, 2017
Tenino, WA
Thanks for advice...used it everyday so far. I can't believe this is my first tractor. Sure beats manual labor.
KennedyFarmer
L3901, with not enough attachments
Jun 8, 2015
289
Pennsylvania
I bet your tractor to-do list before you got it is now wiped clean :D Now your probably on the Let's see, Oh i can do this now! :rolleyes:
CharlieFoxtrot
B2650
Dec 8, 2016
79
Northeast
I kept mine below 2500 RPM for the first 50 hours but got very close to that because I needed at least 2400 RPM to move snow with my front mount blower. I changed all of the fluids and filters and noticed nothing out of order and the tractor is working fine many hours later.
Curt
MX5400 HSTC, RTVX1100C, GR1120, KX040-4
Dec 19, 2010
23
Exeter, RI
www.firelawblog.com
Rookie Farmer - I have the exact same question and it does not appear we can get much more than keep it below maximum RPMs for the first 50 hours...
The problem is - what is maximum RPMs for the B2650? If the engine is rated for 2500... then 2500 cannot be the maximum.
My former B2620 had a redline on the tach. My new B2650 has a digital screen with the RPMs displayed in numbers... And the owner's manual talks about not operating it a "fast speed"...
But it is an awesome tractor... smoother and more stable than the B2620.
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
On mine the maximum is about 2600 rpms.
Utopia Texas
Kubota B2650/Kubota L6060
Jun 14, 2017
110
Brookshire & Cat Spring, Texas
No tractor manufacturer says not to mow with your tractor the first 50 hours so what ever rpm's turn your three point rotary cutter at 540 rpm's is what I use for max engine speed for the break in period.
