3 pt hitch for B6000 from donor B7100
socalkubota
B6000
Apr 1, 2012
20
Vista
Hello OTT, just found a 3 pt on ebay from a B7100 for my B6000. Anything I might need to change or do to mount that? Any advice greatly appreciated.
Kytim
Aug 14, 2009
848
15
Western Ky
it should pretty much swap, if memory serves correct there 3 different length/shape arms for the B7100. as long as the lower mount under the diff is long enough(the rod) and of the correct dia. everything should work. they should stay out of the tires. might look close at the check chain mounting too.
good luck.
