L2350F Tach Drive
John Ha
L2350F, 6 foot finish mower, 5' blade, 5' disc harrow, cultivator, 3-pt scoop
Feb 23, 2024
Mitchell, SD
Greetings all! Recently my 1996 2350F has been unhooking the tach drive cable from the back of the instrument. It's happened twice within 10 operating hours. The first time I just screwed the cable back onto the rear of the tach and made sure it was finger tight - not loose at all. Everything worked correctly.
Yesterday, I found that it had come off again (no tach reading when I started the tractor). This time I used a bit of blue thread locker on the tach receptacle threads before I screwed the cable back onto the rear of the tach.
All this happened out of the blue. The tractor's been a rock - always reliable - since I bought it new. I hadn't even been messing around the instrument cluster before all this happened.
I'm curious to know whether anyone else has had this issue and what might be causing it.
TIA
