2 5/16” ball with 3/4” shank???
BillK01
BX2360, FEL, LP 1560 back blade, Front mount snow blower, Ferris ISX800 ZTR
Mar 17, 2017
169
Near Pittsburgh, PA
Is there such an animal as a 2 5/16” ball with a 3/4” shank? I bought a Titan Attachments draw bar to use with quick hitch and I would like to use it to move my 16” trailer around on occasion.
The trailer uses a 2 5/16” ball but the Titan only has 1 7/8 and 2” balls on it with 3/4 shanks. I know most 2 5/16” balls have 1” shanks due to the weight capacity but my use will be only moving the trailer short distances over flat ground.
I would rather not drill out the Titan to 1” for the larger ball. Anyone have any ideas?
bcp
BX2360
Apr 20, 2011
644
79
SW WA
Just yesterday I looked at an interchangeable ball set. It had 1 7/8 and 2 inch balls, and 3/4 thread size. There was a statement on the package that said there was no 2 5/16 ball because that size was illegal on a 3/4 inch shank.
Bruce
BillK01
Mar 17, 2017
169
Near Pittsburgh, PA
Is this the one you have?
https://www.palletforks.com/three-p...point-tractor-drawbar-trailer-hitch-1286.html
If you just bought it locally, maybe return it and get one with a receiver tube, and get a 3-ball insert.
https://www.palletforks.com/three-point-attachments/trailer-moving-attachments.html
Bruce
Yes Bruce that is it. I bought it off amazon and was hoping to not have to take the hit on return shipping on a 36lb item. It’s my own fault for missing that the one ball was only 2” and not 2 5/16”.
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
44
its illegal for the road..... (where i live)
but walmart has the 2 5/16" ball with 3/4" shaft on the shelf for about $5.
8,252
Can you weld?
Weld on a 2" receiver to that model hitch and it will work much better! ;)
BillK01
Mar 17, 2017
169
Near Pittsburgh, PA
It’s only for use on my property so that’s not a concern. Got link for it?
8,252
It***8217;s only for use on my property so that***8217;s not a concern. Got link for it?
You won't find them online, Drive to Walmart and buy it if available.
I would be surprised if they do have them as it would but Walmart in a heck of a liability suit if they do still sell them. ;)
2,906
Do you do any machining? Know someone who does?
Cut the larger shank off a 2 5/16" ball and drill & tap it for a 3/4" grade 8 bolt.
Ramos
1870-1, LA203A, RCK54
Feb 25, 2016
463
Sherman County, Oregon
Love it! Big ball, little shank: Not safe on the road, bad idea, possibly no longer legal. But heck, WalMart sells them, LOL. Maybe they are trying to eliminate some of those who are on 'People of WalMart' featured on youtube?
I agree that welding a 2" receiver on there is the way to go. Not only solve your 2 5/16" ball dilemma, but make the thing more versatile. Any number of inserts can be made or purchased.
yeehaw48
kubota 6040 tractor, kubota utv 1100c
Apr 26, 2018
ky
why can't you use the 1" shank, just place it in your drawbar. I use one all the time just unbolt when done.
6,334
I looked over those Google links and no such animal is shown. The dimensions would lead one to believe they are there, but the discussion says they are not available for 2 5/16 and the 3/4" shank.
Got to fabricate your own!
GaryL
2003 BX2200 - loader, mower, blower, grss collection system
Nov 22, 2014
119
Holden, MA
I have the same Titan setup. I removed the 1-7/8" ball and drilled out the hole to 1" and replaced with a 2-5/16". If you needed the 1-7/8", it could be swapped with the 2" with the 3/4" shank hole. You can also get a ball that has replaceable heads in the two smaller sizes. Drilling to 1" only took me about 10 minutes and it was solved.
BillK01
Mar 17, 2017
169
Near Pittsburgh, PA
Turns out I screwed up twice when I ordered it. First, not noticing it didn’t have a 2 5/16th ball and second, not realizing it won’t fit on my quick hitch. So back it goes.
2,906
Somewhere in a junk box I have a 2" ball with a 1/2" shank.
I think it was from a Sears lawn tractor that a neighbor used to move his trailers around.
