Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 01-04-2010   #1
Quailtail
New Member
Equipment: M5400
Default How to Determine Year tractor was made?
I am trying to find out what year my tractor is. The plates or stickers on the frame near the front are unreadable. Is there someplace else on the tractor that a person can find the serial number to determine the year of the tractor?
Thank You
Quailtail is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-06-2010   #2
challenger
1st Yr. Apprentice
Equipment: L3000
Default Re: How to Determine Year tractor was made?
This might work-go to Kubota web site and look at prior products-it should show model and year---
challenger is offline   Reply With Quote
Old 01-07-2010   #3
bruceatlam
3rd Yr. Apprentice
Equipment: B20, FEL, box blade, flail mower
The only quick and dirty way that I'm aware of is to check your rear wheels to see if there is a date stamped into the wheel. The assumption, then, is that the tractor ws made close to that date. Nobody worries much about the date. Most all are concerned with the hours of use not the originakl date that it was manufactured. So be it I guess.
bruceatlam is offline   Reply With Quote
Old 01-07-2010   #4
eserv
Journeyman
eserv's Avatar
Equipment: BX24, A1000 Kubota Generator, Bolens (Iseki) G154 with tiller
Kubota serial number locations: B SERIES Models B5100, B5200, B6000, B6100, B6200, B7100, B7200, and B8200 L SERIES Models L175, L185, L225, L235, L245, L275, L285, L305, L345, L355, L2250, L2550, L2850, L3350, L3750, and L4150 M SERIES Models M4000, M4050, M4500, M4900, M5500, M5950, M6950, M7950, and M8950 Serial number plate is located either on the right or left side of transmission case, on forward end (could also be stamped into the transmission case). Engine serial number, in all cases, is located on right side of engine adjacent to fuel injection pump flange on engines that use an in-line fuel pump. On engines that use a rotary pump, the serial number plate is stamped into left side of block. UTILITY VEHICLES Located on the left side above the battery under dump bed.
eserv is online now   Reply With Quote
Old 02-05-2010   #5
Orangefox40
1st Yr. Apprentice
Equipment: B7200HSD_FEL+Blade, 1986
Hi there,
Once you have located the serial number, go to "tractordata.com" where you will find the make and model of you tractor. input the make and model and then look at the serial numbers to idenify the year. This site will also have many other specifications for your tractor model.
Ron
Orangefox40 is offline   Reply With Quote
Old 05-27-2010   #6
Amishkingpin
1st Yr. Apprentice
Equipment: B7100 HST with FEL,Tiller,Rotary Mower and Box grader
I went to tractordata.com but numbers only go to 1986 for SN around 13000.
My B7100 HST serial number is: 66850
Does anyone know where I can find out the year of my tractor?
Thanks, AK
Amishkingpin is offline   Reply With Quote
Old 05-27-2010   #7
handyman
3rd Yr. Apprentice
Equipment: Kubota B7100HST-E
Look here I beleive you will find serial #http://www.tractordata.com/farm-trac...ota-b7100.html should be 1980. handy
handyman is offline   Reply With Quote
Old 05-29-2010   #8
Amishkingpin
1st Yr. Apprentice
Question Re: How to Determine Year tractor was made?
Handyman and Vic,
Thanks, Handyman, I checked with the link you provided. My tractor I believe is newer than a 1980. The reason I think so, is that it is a Hydro and the earlier B7100s were gear in 1980. Also, the person I bought the tractor from, stated he was the original owner and he bought it around 1996 from a dealer new.
Yesterday, I stopped by my local dealer to pick up some parts when I asked him if he could tell me the year of my tractor. He brought out a book and proceeded to look. I found this interesting and maybe Vic could provide more insight here. He showed where Kubota quit making the model B7100 by the late 80's early 1990 and then made they again(Only Hydro models) in the early to mid 90s. The serial numbers showed only up to 58000 for around 1990but my serial number is 66850 and we could only guess. His book may be out of date too. He then looked at my Operator Manual I got with my tractor and he thinks it may be one of the last B7100 made in the mid 1990s.
Vic, can you confirm from your Kubota reference manuals or is there a page on the OTT website I could reference?
Thanks, AK
Old 05-29-2010   #9
williecnc
1st Yr. Apprentice
Equipment: Kubota B7100 HST 4WD
Mid 90's is about right because my B7100 HST 4WD was bought new by my uncle in 1992 and the serial number is 63044. Hope this helps you.
williecnc is offline   Reply With Quote
Old 05-29-2010   #10
Amishkingpin
1st Yr. Apprentice
Good Deal that helps!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
