Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 02-08-2013   #1
Dab4933
New Member
Equipment: Digging, moving dirt
Default L260 Transmission parts?
My L260 has an issue with reverse. It WAS bouncing out so I had to hold it in when backing up. Now it grinds and does not want to move in reverse. When it does move it makes a clicking and grinding sound. I want to fix this trans but before I take it apart I wanted to find a source for the transmisson parts. I expect at the least a reverse gear and fork. If I can find the bearing and other internal trans items I would like to do a complete overhaul.
Does anyone know where parts are available this old but great machine?
Dab4933 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-08-2013   #2
Dab4933
New Member
Default Re: L260 Transmission parts?
I was able to find the Reverse Gear for my L260 from Steen Tractor. This gear has 21 teeth and was part # 32240-23130 (see Pic). I had to separate the tractor about 5 inches to make it work. I took the 4 nuts off the upper center shaft to get to the reverse shaft retainer clip. Once I had the retaining clip off the reverse shaft I had to get enough clearance to get the gear off. I used some long bolts (see Pic) to keep everything aligned so I did not have issues going back together. New gear works GREAT!
Only other issue with this I had was the tower was binding making it hard to move between gears. I pulled back the rubber gasket and put a little oil on it and it moves very easy now. This is old tractor is easy to shift now.
Click image for larger version
Name:	Kub Rev Gear3.jpg
ID:	7358   Click image for larger version
Reply
Tags
grind, l260, reverse, trans, transmission
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
