Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 01-28-2013   #1
Aardvark
1st Yr. Apprentice
Equipment: B5100E
Default B5100E noisy hydraulics
When the three point lift gets to the top of its travel there's a loud squeal, like a cat in a blender. Is this normal? It has always done it. I was thinking maybe it is time to change the trans oil and clean the filter as soon as I can find an affordable equivalent to the Kubota UDT stuff.
Aardvark is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-28-2013   #2
Bulldog
Master Tech
Bulldog's Avatar
Equipment: M 9000 DTC, L 3000 DT
Default Re: B5100E noisy hydraulics
It's the fluid by-passing, the 3pt is at the top of it's travel range. It should have a feed back rod on the right side under the seat that you can adjust. My 7100 did the same thing.
__________________
AMSOIL, protect your investment.
Bulldog is offline   Reply With Quote
Old 01-28-2013   #3
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
My B6100E has done it since the day I got it and I've had it 10 years. I think the squeeling is the relief valve on the hydraulics.
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Old 01-28-2013   #4
Aardvark
1st Yr. Apprentice
Equipment: B5100E
Thanks gentlemen. Then there's nothing to worry about. Apart from the noise I don't get any hassle from my B5100 and it does a good days work for me and barely sniffs at the diesel. I will still treat it to an oil change.
Old 01-28-2013   #5
kubotasam
4th Yr. Apprentice
Equipment: B2410, B7100dt, B7500,Woods BH750,Landpride 2660RFM, Tiller x2, B2660 Snowblower
Do as Bulldog said and adjust the feedback rod and the noise will stop unless you are trying to lift a very heavy load on the 3 point hitch.
kubotasam is offline   Reply With Quote
Old 01-28-2013   #6
Aardvark
1st Yr. Apprentice
Equipment: B5100E
I might give it a try. Just move the rod a little one way or the other? I don't have a copy of a workshop manual so I will be "flying blind".
Old 01-28-2013   #7
B7100
3rd Yr. Apprentice
Equipment: B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Quote:
if you hold off for an hour i'll extract and post the page out of the wsm for you.
dave
B7100 is offline   Reply With Quote
Old 01-28-2013   #8
Bulldog
Master Tech
Bulldog's Avatar
The easy way to do it is to stand beside the tractor, raise and lower the 3pt so you can see how it works on the rod. It should have a small stop that you can loosen up and slide it on the rod. It's a simple process but if you don't watch how it works it's real easy to adjust it the wrong way. If you don't know where the rod is just follow the 3pt handle down under the seat and you will find the rod. Let us know how it works out.
__________________
Old 01-28-2013   #9
B7100
3rd Yr. Apprentice
Quote:
dave
It was in the operators manual so even easier to do :
under 8.6 Implement lifting and lowering limits
dave
File Type: pdf Extract Pages From B5100-B6100-B7100 Owners Manual.pdf (283.7 KB, 105 views)
Old 01-28-2013   #10
Aardvark
1st Yr. Apprentice
Equipment: B5100E
I understand it now. I can adjust the upper limit little by little until it reaches the stopping point without squealing. Thanks for all the help.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
