Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 01-13-2013   #1
jhawk73
New Member
Equipment: B7100 HST
Default Sleeve a Broken Cylinder?
I have a D750 out of a B7100, It sat with the injectors out and must have froze. It broke a section out of the cylinder. Could it be sleeved? I think not, but has anyone tried it or had experience with it ?
jhawk73 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-13-2013   #2
lsmurphy
Journeyman
lsmurphy's Avatar
Equipment: B7001
Default Re: Sleeve a Broken Cylinder?
http://www.kubotabooks.com/AutoIndex...9d6e8aec0f847c
Go to service manual 1 for the 7100 and paragraph 31.
They are all sleeved.
lsmurphy is offline   Reply With Quote
Old 01-13-2013   #3
Service Dept Vic
Service Dept Vic's Avatar
Ya, I'd like to see a few pictures of that nightmare! Possible to upload a few pics for us to look at?
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 01-13-2013   #4
Master Tech
Lil Foot's Avatar
Equipment: 1979 B7100DT
Quote:
Yeah, me too! Don't have that problem, but always trying to learn more about the B7100.
Lil Foot is offline   Reply With Quote
Old 01-14-2013   #5
jhawk73
New Member
Click image for larger version
ID:	6722 I have no idea IF THIS WORKED LOL! But here is the broken cylinder.
Old 01-14-2013   #6
Stumpy
4th Yr. Apprentice
Stumpy's Avatar
Equipment: L175
Here's a word: Yikes!
I guess it kinda makes sense the sleeve would crack under ice. It's probably the hardest and most brittle part in there next to the rings. If it was under enough force to cause that though I'd be wary of cracks in the block. At this point your best bet is to strip it to a bare block and take it to an engine shop to get the liners removed and the block inspected for cracks. They oughta be able to fix it regardless and put some fresh sleeves in there. New pistons, rings, and bearings and you'll have a brand new engine.
__________________
Matt
"The Romans called one of their gods Saturn. We used the name for something more impressive."
Stumpy is offline   Reply With Quote
Old 01-14-2013   #7
jhawk73
New Member
Yes, if i had to I would this is off a parts tractor. I was wondering if hanging on to the block was worth it.
Old 01-14-2013   #8
Apogee
4th Yr. Apprentice
Equipment: B6100, B7100, B8200, B9200, G4200, L175, L35
You might consider ordering 3 new sleeves, pistons, rings, bearings and gaskets and just do the whole thing at once. The machine shop could do the other two pretty quickly and then the engine would be back to original size when they are done. I submit this because with the rust I see in the bore tells me it's been apart for a while. I wonder how the other two look and measure. Any scoring or pitting in the other two and it will use oil and likely short lived. Might as well just start from new.
Just my $.02,
Steve
Apogee is offline   Reply With Quote
Old 01-16-2013   #9
Stumpy
4th Yr. Apprentice
Stumpy's Avatar
Equipment: L175
Maybe. Most engine shops these days can do amazing things with cast iron. It would take some pretty catastrophic damage to warrant a backup block. Where it might be handy is if you know your running engine is dying and you want to rebuild your spare in the mean time and then just swap them.
You ever get out to Pymatuning jhawk? Pretty area. I'm in Ohio about the same drive from it you are.
__________________
Matt
Old 01-17-2013   #10
Apogee
4th Yr. Apprentice
The toughest part of having the thing re-sleeved will be to find a machine shop with a boring head that is small enough. I have been searching my area and have thus far come up empty. The diameter of the boring head for standard automotive work is about the same size as the Kubota cylinder diameter, so there is simply not enough room. Shops that have the smaller boring heads are harder to find. However, that can be easily fixed by calling ones local Kubota dealer and asking which machine shop they use for block work (if they do any).
The other option is to find a shop that rebuilds small engines. Mower type stuff... They tend to have the smaller diameter boring machines but then it comes down to whether or not one wants to trust them with a Kubota block.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
