fast*st
M7040, L2900, F550 ford, Yanmar vio70 excavator, Case 580, JD 350 dozer, JD 644E
Finally almost finished with fabbing up a skid plate for the M7040, working around brush and roots and sticks we've sheared off pretty much all the lines underneath at one time or another and the main line twice once with a stick and once with a snowbank. Also have dented both hydraulic filters as well as tweaked the rear brake linkage. Used a 2x2x 3/8 thick angle iron that runs from the front to rear of the tractor, it has a notch where it goes past a high spot in the transmission and its bolted in six or so places using the 16mm bolt holes, tapped out one hole on the transmission to 16mm and cleaned out the rest. Put some tabs on the angle iron and fitted 1/4 inch steel plates, the plates are small enough to remove. Its bolted solidly along the spine, and so far tied into the flimsy guard under the hydraulics and with a heavy strut anchored to the rear axle, using the plate where the rear sway links hook to the rear axle. Will have to get some pictures but this should protect all the hydraulics and filters.
