Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 11-24-2009   #1
daniel.ray77
2nd Yr. Apprentice
Equipment: 1976 Kubota L225DT
Default L225DT, L2050DT and L2550DT; Are parts interchangable?
Does anyone know if the Front Differential Carrier, spider gears and ring & pinion are interchangable between the L225DT and either the L2050DT or L2550DT?
daniel.ray77 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-24-2009   #2
eserv
Journeyman
eserv's Avatar
Equipment: BX24, A1000 Kubota Generator, Bolens (Iseki) G154 with tiller
Default Re: L225DT, L2050DT and L2550DT; Are parts interchangable?
No they are not, a completely different front axle on the L2050dt and L2550dt than the L225dt. The L2050dt and the L2250dt are the same though.
I looked to see if the L225dt parts fit any other domestic tractor and they do not. Sorry!
Ed
eserv is offline   Reply With Quote
Old 11-25-2009   #3
daniel.ray77
2nd Yr. Apprentice
Sorry, i meant to say the L2000DT. Are parts interchangeable between an L225DT and L2000DT?
Old 11-25-2009   #4
eserv
Journeyman
eserv's Avatar
Some one else will have to help out here. The L2000dt is Gray market and I don't have any information on them! Sorry!
Ed
Old 11-30-2009   #5
daniel.ray77
2nd Yr. Apprentice
My Kubota dealer here in SLC, Utah tells me there are the exact same tractor so all parts are interchangeable.
Old 11-30-2009   #6
eserv
Journeyman
eserv's Avatar
Excellent! Good to know, there is a guy near here has one. He hasn't been in for parts yet but if he does we can help him.
Ed
Old 11-30-2009   #7
Service Dept Vic
Service Dept Vic's Avatar
Some of the final drive ratios may be different because the transmissions had extra gears and extra PTO speeds, as well, the US L225's had larger diameter tires. Do you have a parts schematic for your L2000DT? What "exactly" by reference number do you need?
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 12-01-2009   #8
daniel.ray77
2nd Yr. Apprentice
Sorry Vic, im not sure if your last response was intended for me but i don' need any part numbers for my tractor. The place that sourced the replacement front diff for me somehow was able to verify that my L225DT and the L2000DT matched up. You wouldn't happen to know about how many models of the L225DT were originally sold here in the U.S. would ya?
Old 12-04-2009   #9
daniel.ray77
2nd Yr. Apprentice
So i have just completed installing a differential from a L2000DT from Zen Noh to a Kubota L225DT and it WORKS!!! Took all of about 2 hours to install the new gear set and make ajustments with shims but it WORKS!!! My tractor is once again 4WD. What a difference it makes having 4wd. The thing climbs over anything now especially with a front end loader attached.
Old 04-22-2012   #10
factorten
Equipment: L2000DT
I am chasing a new left diff housing for an L2000DT - I need the housing, and all internal gears as well as the left axle and universal joint that sits behind the outer housing - does anyone have any idea where I can source one of these from?
factorten is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
