Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 09-17-2012   #1
chas8157
New Member
Equipment: B7100 HST
Default B7100 three point lift arms wont lower
Purchased a used B7100. Three point raised at first now is stuck in up position. Any ideas?
chas8157 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-17-2012   #2
meanjean
4th Yr. Apprentice
meanjean's Avatar
Equipment: Kubota L1801
Default Re: B7100 three point lift arms wont lower
Check for a knob under the seat.
meanjean is offline   Reply With Quote
Old 09-17-2012   #3
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
Is there any weight on the hitch? The 3pt is power up and gravity down. You can push it down by hand or have something hooked to it.
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Old 09-18-2012   #4
hodge
Master Tech
hodge's Avatar
Equipment: John Deere 790
Quote:
Yep. The lift arms on my B7100 lower REAL SLOW, unless I push on them, or an implement is on it. It takes weight to evacuate the oil from the lift cylinder, and the arms alone are pretty light. You may need to adjust the knob under the seat, but if it is just a matter of slow fall, then it is pretty normal.
Welcome to OTT! This is a fantastic site, full of good folks. Don't be a stranger.
__________________
Romans 1:16 "For I am not ashamed of the Gospel of Christ..."
hodge is offline   Reply With Quote
Old 09-19-2012   #5
chas8157
New Member
I tried standing on them and they do not budge and I'm not a small guy. I saw the knob under seat. There is a front end loader on tractor. Do you know what position knob should be in.
Old 09-19-2012   #6
chas8157
New Member
Another question to a fellow B7100 owner. Mine is a two wheel drive Hydrostat. Ther is a lever below stearing wheel just about the housing that i have not figured out what its for.
Old 09-19-2012   #7
hodge
Master Tech
hodge's Avatar
below the dash, and to the right of center? That would be the cruise control. When you are moving forward or backward, you pull up on that knob and it is supposed to maintain the position of the pedal. I don't know about others, but mine doesn't grab very well. It works, but it will slow down a little when I take my foot off of the pedal. You push down on it to release.
__________________
Old 09-19-2012   #8
meanjean
4th Yr. Apprentice
meanjean's Avatar
Crank that knob counter clockwise and it should help with lifting/dropping the 3pth
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
