Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 09-16-2012   #1
Erik Graham
1st Yr. Apprentice
Equipment: L2550GST,B7100 HST
Default Clutch Safety Switch?
Greetings All;
I have an L2550 GST that is occasionally very difficult to start. Like most tractors, the clutch must be depressed and the the steering column selector and GST gear lever must be in neutral to start the tractor. What happens often enough is that all of these conditions are met (battery is fine and all lights show go) and it won't start. I can move the steering column lever from neutral to forward or reverse a couple of times-sometimes with the clutch depressed, sometimes not, and it will start once I'm back in the neutral position. Sometimes this doesn't work and I will run the GST gear lever through the gears and back to to neutral. Sometimes this works and sometimes not. I recently replaced the ignition switch and checked connections on any wires I could see. I've been under the tractor several times and can't see anything obvious. When it wants to go the tractor starts easily and everything else electrical works fine.
My thought is that there must be a switch somewhere in the starting circuit that is at best intermittent but I for the life of me I can't see any sign of it.
Anyone else have this problem? Any insights greatly appreciated.
Cheers, Erik
Erik Graham is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-16-2012   #2
birddogger
3rd Yr. Apprentice
birddogger's Avatar
Default Re: Clutch Safety Switch?
My usual difficulty is I think the clutch is down but it only takes about 1/8 inch and it is no-go. So I let the clutch up and stomp hard on it. It could be just some dust and grease binding an actuator somewhere along the way.
But for sure the clutch has to be to the floor board. Just having the pedal in the in-step of my boot makes a difference; for starting I make sure to put the pedal under the ball of my foot.
Try that next time it gets snotty, it is easier than trying to find some of these switches wherever they hid them.
__________________
"Keep my skillet good an' greasy"
birddogger is offline   Reply With Quote
Old 09-16-2012   #3
Erik Graham
1st Yr. Apprentice
Odd you should mention that. The last time I tried starting it I was so p****d off with it not starting I did mash the clutch pedal (in total frustration) to the floor and it did start! I had wondered about looking at making sure there wasn't any slop in the adjustment linkage as well. Will report back next weekend.
Cheers, Erik
Old 09-17-2012   #4
Bulldog
Master Tech
Bulldog's Avatar
Equipment: M 9000 DTC, L 3000 DT
It's strange that Kubota does things different on some models. I don't have to mash the clutch in on my L or M series tractors to start them. They both have safety switches but neither one on the clutch.
__________________
AMSOIL, protect your investment.
Bulldog is offline   Reply With Quote
Old 09-17-2012   #5
pmhowe
2nd Yr. Apprentice
Equipment: L4240, Ford 8N
Hi Erik,
I have an L2550, also, although it is not a GST. I had the same problem, and found that if I pressed the clutch pedal all the way to the floor, it worked fine. Since there was lots of free movement before the clutch engaged, I adjusted the clutch linkage to reduce the free play. Now the safety switch works fine, without pressing the pedal all the way to the floor. It's an easy fix.
Phil
pmhowe is offline   Reply With Quote
Old 09-17-2012   #6
Erik Graham
1st Yr. Apprentice
Thanks Phil, Will take the bag'o'wrenches with me up to the property next weekend. The GST transmission is pretty forgiving but I have noticed from time to time some hesitancy to move from forward to reverse (using the clutch). The fellow I bought it from had had a new clutch installed and it's had very few hours since that. I'm pretty sure now that an adjustment will do the trick. Here's hoping!
Cheers, Erik
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
