Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 11-23-2009   #1
ride24hrs
New Member
Default transmission main drive shaft spline worn out
i have a b5000 kubota tractor. the transmission main drive shaft spline (20 teeth) is worn out. even the coupler on the drive shaft from the engine was affected (also worn out). just now the cross joint of the main drive shaft connecting to the front differential with its spline got worn out. im using my tractor for rice field cultivation. its planting season and my tractor is down. im having a hard time getting the parts. the kubota distributer in this area said that they dint dristribute this model of kubota in this region.
Click image for larger version
ride24hrs is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-23-2009   #2
Ob1kubota
3rd Yr. Apprentice
Equipment: M9540DT
Post Re: transmission main drive shaft spline worn out
No quick fix here sorry I hope some body comes along with parts but being an older Gray Market Tractor the US Dealers won't have parts so go aftermarket with this sites like http://www.hubcityinc.com/index.html. Get ready to do some machine work .
Ob1kubota is offline   Reply With Quote
Reply
Tags
differential, drive shaft, spline, transmission
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
