Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 08-29-2012   #1
MikeL
1st Yr. Apprentice
Equipment: L185F L245DT L1200 L1700 L235 L4530B
Question L235 Hydraulics Relief Valve??????
I recently picked up an L235 with an L1200 loader and a 4530B backhoe. Hydraulics were a mess. The machine had been flipped and the main hydraulic pipe was cut and spliced directly to the loader control. Found a used pipe and replaced. The loader still worked fine. The lift arm control valve was set off in the lock position. Turned it on and arms work, but keep floating up and now there is no pressure to the loader. It seems like the control valve is sticking. I do not see a relief valve on the schematic parts. Only 700 hours on the unit with a new hydraulic pump. Any ideas what to clean/disassemble to fix the issue.
"I do not always drive a tractor, but when I do, I prefer Kubota, Stay Orange my friends!"
MikeL is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-30-2012   #2
lucky24
New Member
Default Re: L235 Hydraulics Relief Valve??????
i had that problem with a fortlift what it was one of the seals in the ram was bypassing i replaced seale and all is fine
lucky24 is offline   Reply With Quote
Old 08-31-2012   #3
MikeL
1st Yr. Apprentice
Talking Re: L235 Hydraulics Relief Valve??????
Removed pressure relief valve from loader control, cleaned it up, and voila. Problem solved.
Old 09-02-2012   #4
ipz2222
Journeyman
Equipment: L235, bx2670
mikel, love that line (stay orange, my friend). Thanks for posting back on what you did to fix the problem.
ipz2222 is offline   Reply With Quote
Old 11-08-2012   #5
Girdlebug
1st Yr. Apprentice
Equipment: L245dt
Newbie here - this is my first go at hydraulics, I just bought a l245dt
My 3pt lift is pretty weak and scouring the wealth of info on OTT, I've flushed the hydro/tranny fluid, replaced hydraulic screen and cleaned out vent tube. It seems better, but still not getting the lift I need for the back blade. I.e. 3 pt lifts when no implement is on, but halts if you put it under weight.
I'm wanting to check the relief valve, but just wanted to check on the process before I pull that plug...can someone give me the lowdown on cleaning that pup? Does it have to be installed at a specific torque?
Thanks and what I've picked up thus far on OTT has me a very serviceable tractor! Thx!
Girdlebug is offline   Reply With Quote
Old 11-08-2012   #6
MikeL
1st Yr. Apprentice
The original pump on the L245 was not overly powerful or speedy. I have a pump on my L185 that was too weak/slow to run the FEL on my L245, but does fine lifting a flail mower or rake. I have pulled the PRVs on all of my machines and tightened them to "just enough" with no issues. My "just enough" is based on what is being held together and size/material. As I remember, you have a couple of o-ring in there. Pull it, clean it out, check that the valve and spring are free, check and/or replace o-rings and snug it back together. If it leaks, tighten it some more. If the lift is still too weak, I would get the pressure out of the pump tested.
__________________
I do not always drive tractors, but when I do I prefer to drive Kubota. Stay Orange my friends.
Old 11-09-2012   #7
amaurymsa
1st Yr. Apprentice
Equipment: L245DT with FEL
Hi Girdlebug,
if you follow indication of MikeL, please come back with pics,
i had(have) the same problem on my 245dt
drained fluid and changed the screen, better but not really fantastic.
so i you solve the problem, let me (us) know...
you speak also of "cleaned out vent tube", where is it?
thanks!
amaurymsa is offline   Reply With Quote
Old 11-09-2012   #8
amaurymsa
1st Yr. Apprentice
Hi Girdlebug,
thanks!
Old 11-09-2012   #9
Girdlebug
1st Yr. Apprentice
Equipment: L245dt
MikeL - thanks for the help. The loader seems to run fine, lifts good and strong - the 3 pt hitch on the other hand is the one that struggles with even light loads. That said, can we assume the pump is putting out sufficient pressure?
Like I said I'm pretty green with hydraulic systems, and associate relief valves with pressure and just wanted to make sure I wasn't going open anything under pressure.
Amaurymsa - one of the great things about this forum seems to be the follow up with solutions. I'll post back my results.
The vent tube on my tractor is right below the seat on my left side (if I was sitting on the tractor). It is a threaded tube that can be removed and cleaned out (recommended on another thread) - mine was full of mud?
Old 11-09-2012   #10
Girdlebug
1st Yr. Apprentice
Equipment: L245dt
Hey one other quick question - does any air have to be bleed from the hydraulic system after cleaning the reflief valave? Thanks.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
