My manual for my B7100 HST says SAE 10w - 30. Can I assume it cannot be the oil for gasoline engines? I had a Qt of Kubota 10w-30, but wanted to just get oil locally if possible. Nearest Kubota Dealer is 30 miles away.. Any thoughts?
X2...... 15/40 diesel rated oils are best. You can get them in full synthetic. Amsoil makes a 5/40 full synthetic. That would be good for you in your climate summer and winter.Run Shell Rotella or Chevron Delo.
Rotella is available at Walmart for ~ $13/gal and is highly, highly recommended.
Delo is usually available at your local auto parts.
Both are very good oils, half the price of Kubota, and are Diesel rated.
Good luck!
Steve
I don't think that's what the book says, at least not till you're operating in 100+ temperatures.15/40 diesel rated oils are best.
You got it- oils have changed since your tractor was made.Motörhead, Thanks for the imput, I will go with 5/40 synthetic, even though I keep it parked inside.
Curious, why the book doesnt recommend those types of oil, unless those types weren't around in the 80's when my tractor was put into service?
