Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 07-22-2012   #1
RThomas56
New Member
Default B7300 Engine D722
I bought a B7300 that had a blow D722 engine.....the guy I bought it from told me they replaced the D722 with a D662 engine. The engine runs good and smooth and cranks right up with no problems. I am interested to know if I replaced the D662 engine with the orginal D722 engine would it perform better. The only problem with this tractor that when mowing it wants to stall going uphill. I looked at the specs on the both engines not a lot of difference.
Last edited by RThomas56; 07-22-2012 at 09:38 AM. Reason: just wanted to add more info
RThomas56 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-22-2012   #2
Breeze
2nd Yr. Apprentice
Equipment: L3700, Box Grader, 60" Bush Hog, Rear Grader Blade, York Rake, Boom Pole.
Default Re: B7300 Engine D722
The original engine in your tractor had 20.5 hp. The engine you now have has 16 hp, 28% less.
If you replaced the D662 with another D772 you would see a 28% improvement in those performance areas related to horsepower such as powering up hill with a rotary mower.
You would also see a corresponding drop in your cash balance once you pay for the new engine : ) A smaller mower would be less expensive........
Breeze is offline   Reply With Quote
Old 07-22-2012   #3
RThomas56
New Member
Thanks for the info......I am thinking I will just run this engine until I need to replace it....I have read at tractordata.com that the hp was the same for B7300 and a G1800 which is where the D662 engine came from. I will keep looking for a D722 and if I can find one at a good price I might buy it.
Old 07-22-2012   #4
Breeze
2nd Yr. Apprentice
Yup.
One in "running" condition will set you back $1200 or so. A remanufactured engine would be double that and new, if available probably $3500 or better.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
