Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 06-10-2012   #1
HUMPHEYDO
New Member
HUMPHEYDO's Avatar
Equipment: BX25
Default bx25 front tire leaks
i have had this prob from the first month, i told the dealer he offered to put in a tube, for a price..... i have taken it in and the tire people took it off the rim cleaned it and sealed it but no deal still leaks. i thought it was the valve because it was leaking from there then i tightened it, now it leaks from the rim very slow leak but a leak all the same SIGH......... any advice before i tube it or shoot it. def a rim leak tho. second prob was the light switch hazzard lights or turn signal turn on ramdomly, took apart the switch top to bottom and cleaned every bit no prob now took about 30 min to clean.
HUMPHEYDO is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-10-2012   #2
ipz2222
Journeyman
Equipment: L235, bx2670
Default Re: bx25 front tire leaks
you could try one of the liquid tire sealers.
ipz2222 is offline   Reply With Quote
Old 06-10-2012   #3
Bulldog
Master Tech
Bulldog's Avatar
Equipment: M 9000 DTC, L 3000 DT
Like IPZ said, try some Slime in it. I use it all the time around the farm. Always seems to take more than what it says to use on the jug but if it stops the leak it's worth it. Works in tube type or tubeless just fine.
__________________
AMSOIL, protect your investment.
Bulldog is offline   Reply With Quote
Old 06-10-2012   #4
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
Did you maybe rub the rim against something hard and put a kink it in a little bit? Another common problem too is dirt gets between the rim and the tire and causes air leaks as well.
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Old 06-11-2012   #5
GWD
4th Yr. Apprentice
GWD's Avatar
Equipment: M7040, L48 TLB, BX2200
BX front tire leaks are a common problem. Be sure to pump up the tire and spray it with soapy water to diagnose the leak(s). A lot of times it will leak through the sidewall on Kubota tires. Tubing it is the way to go for a permanent fix but Slime usually works too.
As for the lights - the dash switches are not waterproof. It is a common problem for the lights to flash or go on without using the switch. I disconnected mine and left them that way.
__________________
2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
2002 Kubota L48 TLB, 12", 18", 24" HD buckets
2001 Kubota BX2200, Turf, LA211 FEL
7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, 6', 4' flail mowers, 6', 4' rototiller, 6', 4' Bush Hog mowers, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, 8' offset disc, lots of misc.
GWD is offline   Reply With Quote
Old 06-11-2012   #6
lreops
3rd Yr. Apprentice
lreops's Avatar
Equipment: L3400DT W/ LA463 FEL and L235DT W/ BF400 Loader
I came across this on another site, don't know whether it has any more info to help or not, but decide for yourself.
http://www.tractorbynet.com/forums/s...54#post2887254
Ron
lreops is offline   Reply With Quote
Old 06-11-2012   #7
Service Dept Vic
Service Dept Vic's Avatar
Ya, I was thining dirt and crap in the tire beat seating area too, but since the tire was broken down, cleaned and re-sealed that seems unlikley now.
I'd be inclined to think there may be some poirosity in the wheel at a weld; which alot of us have seen over the years on vehicles and equipment.
If the BX is still under waranty that would be covered.
If it's off basic warranty the easiest fix would be to Slime it or tube it.
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 06-26-2012   #8
HUMPHEYDO
New Member
HUMPHEYDO's Avatar
Equipment: BX25
WELL i guess i will slime it this was that way from the start, even after being broke down cleaned and resealed still leaks sigh..... thanks for the advice all. cant see shooting her yet still many good years to come
Old 06-26-2012   #9
TripleR
Journeyman
TripleR's Avatar
Equipment: BX2200, BX2660, L5740 HSTC, M8540HDC and some other tractors and equipment
My dealer gave me a new tire wheel combination, first one also leaked, but the second is holding air after over three years.
I did not want tubes or slime.
TripleR is offline   Reply With Quote
Old 06-26-2012   #10
Kytim
4th Yr. Apprentice
Equipment: B6000DT, B7100DT,Snowplow, RM360, Scoop, Cultivator, Carryall,Disk, plow
I bought a bottle of that green slime at a walmart a while back. Dont recall brand, maybe American something or other. Anyhow, the the fronts on my B7100 were originally on a Big ZTR of some sort that my nephew re-shod because the bar tread was tearing the sod up to much at his place. Free tires! Correct size!! Whoo hoo! But as would have it one would leak down fast, somehow after I put them on. It seemed to come right through the sidewall.
Half a bottle of that green gunk and a half hour of use later, I began to see small bubbles on the sidewall. I was ***very*** skeptical of its properties. Anyhow, after its chores were done for the night i parked the old girl so the leak was at the lowest point. Now three months later, it hasn't changed a PSI that I can tell. I will use this secret potion again. Its not real cheap but, in the whole scheme of things, certainly not expensive. About a third of the price of a tube. Best thing, I didn't have to take the front wheel weights off to take the wheel off to get it fixed with a tube. That takes me more than two hands for some reason. As I said I ^^^will^^^ use slime again.
__________________
Kytim
Bro. Timothy S. Midkiff
Romans 10:13-15
B7100DT, B6000DT
Whatever you do, work heartily, as for the Lord and not for men. Col. 3:23
Kytim is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
