I finally got back to this.
Sorry - I don't have a video or pics, but I wrote this up in one post...
We will start with the right foot:
You have 2 brake pedals, a right and a left. Use one or the other to 'help you turn on a dime' or both together to stop.
To the left of the brake pedals you see a lever with a ring handle. That would be your parking brake. Press down your brake pedals and lift up on the ring to lock the pedals. To release, just push the brake pedals.
Also in the same general area of the parking brake, there is a lever attached to your throttle mechanism. You lift up on that lever to shut the fuel off to the engine - (this is the CORRECT way to kill the engine - more on that later)
Further up - to the right of the dashboard is the long rod that runs from the brake area up to the hood. That would be your throttle lever. It works reverse of how you'd think... Push forward to slow down and pull back to speed up... unfortunately it does cause problems if you are running in some heavy brush or low trees and a tree limb or vine cathes the throttle lever - you will find that it will push it to wide-open throttle when you least expect it...
Getting back to your right foot... to the right and below the brake pedals is a small foot lever - that is an accelerator pedal... you can use this when your hands are otherwise occupied and you need extra throttle... a good example - if I'm mowing and I have my throttle set where I want and hit a patch of thick grass or am climbing a hill, I'll step on the accelerator a bit to give it a little extra juice without messing with the throttle setting...
Now BEHIND your right foot is a good weapon to keep in mind - as long as you understand how to use it...
The horizontal bar that you can step on with your right heel is the differential lock.
Should you find yourself in a place where one back wheel begins to spin but the other just sits still, you can step on the diff lock and engage both back wheels... like having a solid rear axle... be advised tho - this is for temporary use and only when going straight... I wouldn't suggest trying to make any turns with diff lock engaged. (Oh... also, don't engage diff lock with the engine wide open in high gear and one wheel spinning ridiculously fast... that would NOT be a good thing...)
Further up between the right fender and the seat is the hydraulic lift control. Pull back to raise up, push forward to lower... this works together with the adjustment knob just beneath the seat. This knob will control how fast the hydraulics will release (or lower).
On to the left foot:
That's a clutch pedal... not sure what else I can say about it.
Behind your left foot is the range lever. Push all the way back for low range and all the way forward for high range. And just an extra thought here - if you're riding along and hit a few bumps and suddenly the tractor just stops moving.. like it's in neutral.. you may want to check and make sure your foot didn't hit the range lever and knock it out of gear before you spend 15 minutes checking the gearshift, shut off the tractor, walk back to the house and get the truck and chain to pull the tractor back to the house and start gathering your tools to tear into the transmission... (not that it's ever happened to me like that before... I'm just sayin'...)
Ok... PTO shifter - that the one on the left. There's 4 speeds on the PTO. Typically you will only use speed #1. The tachometer on the dash has an indication mark for '540 PTO'... that's when the PTO is in 1st.
I have used PTO 2 when I'm mowing short grass and kicked the engine down around 1800 RPM, but that's rare...
Then the gearshift is on the right... not sure what to say about that one either, other than I wish there was more than just 4 speeds and 2 ranges... I find myself wanting 'slower than 2nd, but faster than 1st' a lot...
On the dash - the black knob on the left is the cylinder pressure relief. This is used to help START the engine - you can pull that out, get the engine turning over, and release... typically only helps in cold weather... a lot of folks (my kids included) think that's how you kill the engine.. it does, but you really should use the fuel shutoff I indicated above...
The big black knob on the bottom right of the dash is the glow plug and starter switch. Turn it one way to heat the glow plugs for a few seconds before turning it the opposite way to engage the starter. In cold weather give the glow plugs a little extra time to heat up to get the engine started. In especially hot weather - you probably won't even need the glow plugs...
That's all I got... I hope it helps...
Maybe someone else out there can add pics to it???
