Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 06-02-2012   #1
jbw1776
Default Kubota L235 Hydraulic Lift Problem
Hello all. Been reading for about a year since I got my 1985 L235 but never needed to ask a question until now.
When I bought my 235 I serviced the whole machine, engine oil, hydro/Trans oil, all filters, etc. It has a little over 300 original hrs. Bought from old man who used to till a garden each year. All I use it for is to pull a 5' 3-point bushghog to cut my deer lanes each year. Last year everything worked fine. Took it out today to cut some overgrown lanes and it worked for about an hour or so and then I started having trouble lifting the 3-point, until it just wouldn't lift anymore. Was about 2 hrs trailered back home and when I cranked it it lifted like usual once it was cooled off.
Now I have about 6hrs total on the hydraulic oil and filter. Aftermarket oil (utg equivalent), Kubota Hydraulic filter. Level is full, no pinched lines. I did notice when coming back down a very long lane back to the trailer, the whole time trying to lift the bushhog, that when I go to the trailer I saw a very little bit of smoke coming from what looked like the hydraulic pump (was behind the side panel so I couldn't see if it was oil burning or what, but it quit right after.
Reading this forum I see where the L series had either the stainless wire screen in the tranny and then they converted to the screw on canister on top of the hydraulic pump (Like mine).
I will say that since I've owned it if you are idling and lift the 3-point it won't raise the bushhog until I idle it up and then it lifts fine.
Is my pump weak and finally kicked the bucket? Could my new Kubota filter be bad and its plugged up? Any ideas as to where to start on this thing?
Sorry for being long, just wanted to be thorough. I appreciate any help you can give.
James
jbw1776 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-05-2015   #2
dwc1252
Equipment: mowing
Default Re: Kubota L235 Hydraulic Lift Problem
I am having trouble with the lift on my L-235. Do I need to change the filter first, then go from there?
dwc1252 is offline   Reply With Quote
Old 08-05-2015   #3
VIP Service Tech
North Idaho Wolfman's Avatar
Equipment: L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat, and more
dwc1252,
I sent you an email with a link to download the WSM for your tractor.
read that and go through the trouble shooting guide on it.
Yes cleaning or changing filter/screen is a good thing to do but not sure that's your problem.
I would trouble shot first then tear into it.
__________________
Some days you're being chased by the wolves,
Some days you're running with the pack!
North Idaho Wolfman is offline   Reply With Quote
Old 08-05-2015   #4
project_x
1st Yr. Apprentice
Wolfman,
Is there any chance you could pass on the link to the WSM to me as well. I have the paper version, but would love to have it digitally.
Thanks,
Rob
project_x is offline   Reply With Quote
Old 08-05-2015   #5
VIP Service Tech
Quote:
Originally Posted by project_x View Post
Wolfman,
Thanks,
Rob
Done, check your email.
__________________
Old 06-08-2016   #6
Rosgood14
1st Yr. Apprentice
Equipment: L235 4x4
Quote:
Originally Posted by North Idaho Wolfman View Post
dwc1252,
Hey Wolfman could I get you to send me the link to the WSM as well plz. Thanks
Rosgood14 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
