Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Fabrication & Customization
Fabrication & Customization Show off and share the details of your custom improvements to your tractor, your truck or anything else you get your hands on.
Reply
Thread Tools Display Modes
Old 04-03-2012   #1
ranger4327
1st Yr. Apprentice
Equipment: L3800
Default 3PTH Ballast Box
Looking to make a 3PTH ballast box for my L3800. I am thinking of using cement in some sort of form, with the 3pth encased in it. Whats the cheapest way to accomplish this? Anyone have any ideas? Thoughts, pictures?
I am thinking of purchasing some sort of 3pth, building a form of some sort, and encasing it in cement....
was looking at Northern Tools at
http://www.northerntool.com/shop/too...5619_200315619
http://www.northerntool.com/shop/too...2832_200342832
and pouring cement around them in a form....will it work?
thanks !!!
ranger4327 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-03-2012   #2
Kytim
4th Yr. Apprentice
Equipment: B6000DT, B7100DT,Snowplow, RM360, Scoop, Cultivator, Carryall,Disk, plow
Default Re: 3PTH Ballast Box
As far as the cheapest form material I can think of is a small steel drum like grease comes in. Or i saw one that someone had a short piece of plastic corrugated drain culvert. you could use the cardboard rediforms for pouring concrete columns and piers. braced up correctly a plywood box would be just fine and could be left on after curing too.
I'm sure there are many other great ideas out there.
__________________
Kytim
Bro. Timothy S. Midkiff
Romans 10:13-15
B7100DT, B6000DT
Whatever you do, work heartily, as for the Lord and not for men. Col. 3:23
Kytim is offline   Reply With Quote
Old 04-03-2012   #3
ranger4327
1st Yr. Apprentice
Equipment: L3800
Thanks Kytim.... I think I am good to go for the cement form, but any thoughts on the Draw bar and stabilizer in the links above from Northern Tool ? Just wondering if they would be rugged enuff for the weight of the cement.... Or should something else be better ?
I was just going to build a wooden form or use a plastic barrell kinda like you mentioned !!
Old 04-03-2012   #4
Stumpy
4th Yr. Apprentice
Stumpy's Avatar
Equipment: L175
I'd be worried about the cement cracking about the draw bar. That thing will have to endure a lot of jolting. I'd rather have it encased.
This is what Kytim is talking about. Might Dodge has pictures of his on page 2.
That thread has a lot of different options. Personally I'd go with a 55gal or 30 gal drum and weld the draw bar to it. I've seen something similar done with a metal trashcan which was then used as a ballast\salt bucket.
Stumpy is offline   Reply With Quote
Old 04-03-2012   #5
moderatmixed
1st Yr. Apprentice
Kubota makes a metal box. I started down the same path as you, but by the time I priced the metal, considered the time to weld a three point hitch, etc I decided that the $200 was an acceptable price to pay. I filled it with concrete from Home Depot. I tilted the box by placing the rear on a 2x4 so when dry, the concrete top would slope from front to rear and any water would drain to the back of the box. Lastly I drilled 2 drain holes in the box to allow any water to drain off. The total weight is 480 lbs with concrete and some scrap metal that I through in to provide some structure. Too I added 2"U" bolts so as to provide lifting points. Some times it is just worth paying the price. The box has worked beautifully.
Click image for larger version
moderatmixed is offline   Reply With Quote
Old 04-03-2012   #6
pat331
3rd Yr. Apprentice
Equipment: L35, mower, bushhog, cement mixer, grader, boxblade, forks, posthole digger
Here is my counter weight. I haven't weighed it, but guess it weighs in at 800 to 900 lbs. I made it for at least 6 years ago and it shows no signs of cracking. I put a ball on the back to move trailers if needed. Please post pictures of your creation. Good Luck!
pat331 is offline   Reply With Quote
Old 04-03-2012   #7
Stumpy
4th Yr. Apprentice
Stumpy's Avatar
Equipment: L175
Filled to the top!? Jeese the front tires must float with nothing in the bucket! I surprised it can lift that thing.
Correction, 55 gallons of concrete is a max of 500lbs or less depending on density. Fill'er up!
Correction to the correction, that number above is actually in kilograms. 500kg=1100lbs
Old 04-03-2012   #8
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
Do a search on here for ballast boxes, there's been all kinds of great ideas used in the past from fellow memebers!
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Old 04-03-2012   #9
Kytim
4th Yr. Apprentice
As has been said, there are many ways/ideas to make a ballast box. If you notice I didnt say how I would make one.
If I was making one, 1/8th or 3/16ths steel welded box with welded pins and toplink and 2" receiver hitch external D rings and chain hooks all connected. poured concrete with mixed sizes of pvc pipe placed vertical for handles and chains. a molded in chicken coup and garden gnome. naw, forget the chicken but everything else would be good.
Not necessarily cheap way to do it though but, would be very versatile. oh, dont forget the slow moving vehicle sign.
__________________
Kytim
Romans 10:13-15
B7100DT, B6000DT
Old 04-03-2012   #10
pat331
3rd Yr. Apprentice
My L35 handles the counterweight ok, but does groan. If my math is correct, a 55 gallon drum has a volume of appx. 0.27 cy. And a cy of concrete weighs in at 3000 lb/cy, so that figures to be about 817 lbs. plus all the steel I put in it. Maybe one of these days I can get the thing weighed. The L35 has a heavy FEL and the heavy counterweight is needed to keep the rear on the ground. I have to be careful picking up anything that maxes the FEL. The tractor is most stable with the BH on. I have water/antifreeze in the tires and would like to come up with some wheel weights to keep it grounded.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
