Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 10-22-2009   #1
Warcloud
New Member
Equipment: BX2360, FEL MMM,
Default Block Heater
Thought about using a magnetic oil pan heater for my BX 2360 instead of installing a block heater. Anyone ever used one? Is it safe to do or should I just put in a block heater.
Warcloud is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-22-2009   #2
Ob1kubota
3rd Yr. Apprentice
Equipment: M9540DT
Default Re: Block Heater
Welcome Warcloud and for what my two cents is worth on this subject; I used them in the late sixties and early seventies when they were all the rage. They worked but the dip stick type would burn your oil in as little as 15 minutes if not removed. They are simply induction coils that heat as current is past through the element. They are available in several wattages from as low as 50 - 1,000 watts. If you insist on a mag heater go look at this site: http://www.padheaters.com/.
Ole OB1's advice consider the expense of a water jacket block heater. It will never cause a fire, if it shorts it will immediately blow a fuse or trip a breaker if 115 VAC plug in type. The coolant has a natural circulation because of the density of water Vs oil and that teamed up with a 0-30 synthetic oil will work in 40 below weather without engine wear during cold friction starts.
Ob1kubota is offline   Reply With Quote
Old 10-22-2009   #3
eserv
Journeyman
eserv's Avatar
Equipment: BX24, A1000 Kubota Generator, Bolens (Iseki) G154 with tiller
I agree with OB1 Use a coolant heater. For all the reasons OB1 wrote plus it will get your engine warm enough to start much quicker. Not that a pan heater is a real bad idea, but they are never as satisfactory as a block heater. The Kubota heater for your engine is very easy to install.
Ed
eserv is online now   Reply With Quote
Old 10-23-2009   #4
chiefbuzzbee
1st Yr. Apprentice
chiefbuzzbee's Avatar
Equipment: B6000 w/Loader 2013 L3800 w/Loader
Send a message via Yahoo to chiefbuzzbee
Smile Re: Block Heater
Thank you all! I have been thinking about the same subject Warcloud for asking the question and Ob1 for the answer and eserv.
I'm checking with my dealer on the heater now, Oh one other thing the 0-30 synthetic oil ? Do you find it to work the best?
With the amount my B6000 takes even I can afford to use. Thanks again guys, Jerry
chiefbuzzbee is offline   Reply With Quote
Old 10-23-2009   #5
Ob1kubota
3rd Yr. Apprentice
Equipment: M9540DT
Jerry when my Nephew was stationed at Elmendorf AFB ( He was a Master Chief over F16 Maintenance) thats all they used in the winter months in all their small liquid diesels. Go figure, Uncle Sam does it right
Old 11-03-2009   #6
VIP Service Tech
skeets's Avatar
Equipment: BX 2360
Well let me ask this, since i am a newbee to the big orange,, Im wondering if a unit that goes in the radiator hose would work to keep things toasty,, though my BX 2360 will be in the pole building out of the weather is a heater really nessary? I know questions questions questions!!!!
skeets is offline   Reply With Quote
Old 11-03-2009   #7
joekimtkd
2nd Yr. Apprentice
joekimtkd's Avatar
Equipment: B7510DT, 4' Snow blower, 4' Loader, 6' Blade, 6' 3PH Finish mower, 6' box blade,
http://www.youtube.com/watch?v=jXl2Joq4ono
Above link shows -4 Fahrenheit (= -20 Celsius) cold start.
Look a like he left it outside all night and started.
My B7510DT manual says use glow plug for 10 second pre heat -5 to -15 Celsius. and below -15 Celsius, should use engine block heater.
I'm keeping tractor inside of garage all times. so I don't think my non-heated garage would go below -5 Celsius...
Good luck.
Joe.
joekimtkd is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
