new fiter and housing. my lil tractor fit on a 5x8 with a tool box on it.
Nicely done! Lookin goodnew fiter and housing. my lil tractor fit on a 5x8 with a tool box on it.
Whoops wasnt paying attention to the "notifications"BoostedB7100, you get my PM?
The turbo is big, there is only 1 turbo I know of that is smaller(-2mm exducer) its a Garrett gt12 and they are quite expensive and would have been much much harder to fabricate on to my tractor. Even being over sized its still not enough to be inefficient.The pressure I'm running is a very safe pressure, I would rather my tractor run good for a long time rather than run really good right before the cylinder head separates from the block. Its not that the d750 wont push the turbo past 5psi, that's just what the waste gate is set at until i get more testing in. I don't know if you know this but in a naturally aspirated diesel compression is anywhere between 22:1 and 26:1 (roughly 500psi). This is very high pressure, when adding a turbo to an engine with this high of compression you should never ever exceed 12psi. If you want to go higher boost pressure you must lower the compression of the engine. Factory turbo diesels usually range from 16:1 to 19:1 making higher boost pressures possible without blowing the cylinder head off.Ive been thinkin about doing this for a while now on my 7200 it has the 950 in it. Iam hoping to get everything under the hood. I think your turbo is to big for the 750 by quite a bit, like about 3 times too big, thats why your only getting 5 psi.
Iam shootin for 15-20 psi. For best overall preformance, and economy.
kubotakid
i noticed ur can of paint. is that by chance the valspar brand kubota orange?
You should put a wanted ad in the sell section- perhaps someone has an old one. You can buy them from Kubota, but I don't know if they just sell the center section. I do know that the complete replacement is expensive.i noticed ur can of paint. is that by chance the valspar brand kubota orange? also i was wondering if you or one of the other guys would know where to lacate one of the small turnbuckles on the lower 3 point bar? im missing the center female theaded piece. any ideas?
The TD03(my turbo) is a factory D950 turbo in many many applications such as bobcat excavators etc. , the factory waste gate on a d950 is set at 6psi just like every other td03 known to man. If you want to push 15 to 20 psi that's great, but have fun picking your valves up off the ground [/QUOTE
Boost
A friend of mine built a 1/4 scale puller and used the D950, Like I have.
He has a steel spacer under the head, Its not very thick, like maybe 1/16th, Its also his garden tractor. He runs about 18 lb boost. No problems.
He built it 2 years ago..
Iam curious, about this D950 OEM turbo your talkin about.? This is news to me that kubota ever turbod the D950..
Where can I find Imformation on the specs? etc.
As far as turbo sizes go, I think this one might be the smaller.., Brand New for about $250.00
