Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 10-17-2009   #1
Joe Kelly
1st Yr. Apprentice
Equipment: L5030
Default 800 hours: Valve clearance
My book says I am supposed to contact my dealer for this item on my 800 hour service: Adjust engine valve clearance.
Any thoughts from you fellows as to how important this might be?
I am quite a distance from my dealer and can't trailer my tractor to him so I'd have to pay the high cost of a service guy driving a lot of miles to get to me.
Joe Kelly
2004 L5030D
Joe Kelly is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-18-2009   #2
eserv
Journeyman
eserv's Avatar
Equipment: BX24, A1000 Kubota Generator, Bolens (Iseki) G154 with tiller
Default Re: 800 hours: Valve clearance
I think valve clearance is very important. That being said the Kubota engines don't seem to get out of adjustment much. Maybe you could buy a service manual and learn to do it yourself? It really isn't very hard. Or maybe there is a local mechanic who could check it for you?
Ed
eserv is offline   Reply With Quote
Old 10-18-2009   #3
Theekillerbee
3rd Yr. Apprentice
I'm assuming that by valve clearance they are talking about the space between the valve stem and the rocker arm? If that is the case, like eserve said, it shouldn't be much of a problem with a set of feeler gauges and a new valve cover gasket.
Theekillerbee is offline   Reply With Quote
Old 10-21-2009   #4
Joe Kelly
1st Yr. Apprentice
Equipment: L5030
Thanks very much guys!
that valve clearance thing is totally new I've never had a diesel before. It is not something that comes up routinely in gasoline engines, as far as I know.
Great to hear Kubota engines are pretty good for staying in adjustment!
As much as I'd like to give the business to my dealer, he is a long way off and there is a competitor a whole lot closer and finances can force one to do what is prudent.
So I shall not ignore the service recommendation but will use a local mechanic to get it done.
Joe K
Old 10-21-2009   #5
Ob1kubota
3rd Yr. Apprentice
Equipment: M9540DT
Thumbs up Re: 800 hours: Valve clearance
Joe I want to add one more thought to the recommendations already provided. On cold start up listen for valve chatter ( clacking in the valve cover ) if it grows louder as the tractor warms up you need to check the valve lash. It will do a lot of damage to your valve seats causing hot spots because the wear lash ( out of adjustment from factory specification due to metal to metal wear as the engine breaks in ) will not allow the lift needed to cool the valve face and seat relationship not to mention overlapp needed for peak torque and Horse power output ( mechanical advantage ). Give the old ear a shot at finding this noise and judge it using your God given senses before worring about nothing. It's like Ed said, Kubota's valve trains are superior to other diesel manufacturer specifications.
Ob1kubota is offline   Reply With Quote
Old 10-21-2009   #6
Service Dept Vic
Service Dept Vic's Avatar
I can honestly say that I've never had to adjust valve lash due to general engine wear, only when the cylinder head came off.
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 10-25-2009   #7
Joe Kelly
1st Yr. Apprentice
Equipment: L5030
Smile Re: 800 hours: Valve clearance
Now, that's good news! Especially for my financial situation! I do want to do what is "right" by my tractor and I strongly believe in good pm, but the cost of bringing a mechanic to my tractor was going to cost a lot more than the proceedure and I really can't afford that!
Thanks, Ob1kubota, and congratulations on moderator appointment! I do listen to start ups....and the loud clatter is very brief....one to two seconds. As it gets colder, as in below 20F, that's when I plug her in for an hour before starting and I have a "quieter" cold start. It is comforting to know that I need not worry about valve clearance until or unless that clatter persists beyond the brief few seconds at start up!
It's also a big comfort to hear Vic say he hasn't done any "routine" valve clearance adjustments, only in conjunction with another job involving tearing the engine down.
Thanks again, fellows! Much appreciated!
JoeK
Old 04-19-2011   #8
asbug
2nd Yr. Apprentice
Equipment: B7001 - looks orange to me... Woods 5' scrape, 42" rotary cutter, shreader/chip.
Not trying to ressurect an old subject, but my B7001 has unknown hours on it and was just wondering if this would help. It is a '77 model, and doesn't appear to have ever been serviced on the inside of the engine.
Someone on another thread stated that the engine ran better after adjusting the valves.
Mine runs OK and is only clanky in the valves when cold...
Just wondering if it is worth the trouble.
KC
asbug is offline   Reply With Quote
Old 04-19-2011   #9
Babyfat
2nd Yr. Apprentice
Babyfat's Avatar
I have to agree with Vic, as a matter of fact we have a Kubota RTV900 that has 11,840 hours on it and has never had then adjusted yet.
__________________
www.dakins.com
Babyfat is offline   Reply With Quote
Old 03-24-2014   #10
fast*st
2nd Yr. Apprentice
Equipment: M7040
a relight of a relit post,
Kubota M7040 was running a little rough at idle and smoking a bit more than usual, 1600 hours and the valve lash was more than a bit excessive. Valve cover spec and dealer spec was .015mm. Front two cyls were just a little loose, maybe 018 or so, but the rears were super sloppy, 025 or better. The 7040 needs a bit of digging, remove power steering gear, air intake tube, cover intake with coffee cup remove muffler, and big bracket over the valve cover, clean everything again then remove glow plugs, injector lines and valve cover.
worthwhile to adjust
fast*st is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
