Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Tractor Operating
Tractor Operating Wondering what that strange lever does, how to safely hill climb or get into 4WD? Discover and share how to get the most out of your tractor.
Reply
Thread Tools Display Modes
Old 01-13-2012   #1
apn73
1st Yr. Apprentice
Equipment: B4200 with RC44-42 belly mower and FEL
Default Block Heater
Hello All,
I have see references around this website/forum about magnetic 1500 watt heaters that you stick onto the oil pan of your tractor and use that cold weather block heater. The largest I can find is 300 watts, can someone send me a link to one of these 1500 watters?
Thanks,
Adam.
apn73 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-13-2012   #2
birddogger
3rd Yr. Apprentice
birddogger's Avatar
Default Re: Block Heater
I'm seeing the same thing you are finding.
If you think about it, 1500 Watts is about the same as a burner on an electric stove. Would you really want to leave that "on" under a pan of oil?
I've seem some higher Wattage "frost-plug" heaters. There, there is no fire hazard, and the circulation of the water would spread the heat around.
birddogger is offline   Reply With Quote
Old 01-13-2012   #3
apn73
1st Yr. Apprentice
Totally get what you're saying, but magnetic heaters that I have found have had a thermostat control.
Old 01-28-2012   #4
mlatour3300
1st Yr. Apprentice
Equipment: B3300SU
I installed a Kubota block heater ($40) and really like the way it works recommend it highly.
mlatour3300 is offline   Reply With Quote
Old 01-29-2012   #5
Ancbill
1st Yr. Apprentice
Equipment: Bx2360, 54" mmm, BX2750D snowblower, RB0560 rear blade, psycho border collie
I too have a block heater. I set it up on a digital timer that I got at lowes. Works great, I have it go on every morning In time for me to clear the drive before work. Also goes on just before I get home. It really heats the entire engine even in below zero temps.
Ancbill is offline   Reply With Quote
Old 01-29-2012   #6
Gundoctor
2nd Yr. Apprentice
Equipment: Kubota M7040 4x4/ BX2230 4x4/ JD MX 8/ Ford 101 Moldboard 3 bottom Plows -
I have had many diesel tractors and the block heater is the way to go. I now have them on my BX2230 and new M7040. They start just like in the summer.
Dave
Click image for larger version
ID:	4728   Click image for larger version
Gundoctor is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
