Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 10-08-2011   #1
kemptvilleguy
1st Yr. Apprentice
Equipment: LS 2500
Default Hydraulic Cylinder rebuild
I did a thread search and found one that said the cylinders were relatively easy to rebuild so I went ahead and got the seal kits. Maybe I'm missing something. The part that threads directly into the cylinder (believe its called the head) has an inner seal right in the centre of it. Does that "head" come apart into 2 peices? If so is it threaded or pressed? I cannot seem to figure out how to get that seal in withouth that head coming apart. Any help would be MUCH appreciated.
Thank you
Bruce
kemptvilleguy is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-08-2011   #2
Bulldog
Master Tech
Bulldog's Avatar
Equipment: M 9000 DTC, L 3000 DT
Default Re: Hydraulic Cylinder rebuild
Is the seal you are talking about just a O-ring or what?
I really wouldn't think the head is pressed on. If it was the hyd pressure probably would just pop it off the rod.
__________________
AMSOIL, protect your investment.
Bulldog is offline   Reply With Quote
Old 10-08-2011   #3
eserv
Journeyman
eserv's Avatar
Equipment: BX24, A1000 Kubota Generator, Bolens (Iseki) G154 with tiller
We use a special tool which twists the seal so we can get it in. I have managed to get them in there with a screwdriver too but I much prefer my tool!
Click image for larger version
eserv is offline   Reply With Quote
Old 10-08-2011   #4
Bulldog
Master Tech
Bulldog's Avatar
Eserv, I bet that little nugget does save you lots of time.
__________________
Old 10-08-2011   #5
Dad03
1st Yr. Apprentice
Equipment: L3200HST
I just replaced the seals on one of mine. The center seal came out with a pick and a little patience. The new one went back in by hand and a little more patience.
Dad03 is offline   Reply With Quote
Old 10-14-2011   #6
kemptvilleguy
1st Yr. Apprentice
Equipment: LS 2500
So as it turns out, the Kubota dealer (by chance) gave me the wrong seal kit but was kind enough to exchange the wrong ones for the right ones. The centre seal was a peice of cake to get in as it was the correct thickness. I thought I was laughing but not so. There are 3 "rings" on the opposite end, 2 of which simply split and stretch off of the piston but the centre one is not rubber or is a hard rubber that doesnt retain its original shape and size after its been stretched and there is NO way that I can see to get it on without stretching it. I even tried soaking it in boiling water to no avail. I've mangled one already and am fit to be tied so I was hoping someone could shed some light on how to get those on. Would be much appreciated.
Thanks again
Bruce
Old 10-14-2011   #7
johneich
New Member
Equipment: B7200
I assume you soaked them in hydraulic oil, I heard of one guy that boiled them in hydraulic oil, I am not recommending it, but if you do, do it outside, on a camp stove.
johneich is offline   Reply With Quote
Old 10-14-2011   #8
eserv
Journeyman
eserv's Avatar
Quote:
Thanks again
Bruce
You work them on CAREFULLY with a small seal pick being careful to not nick the seal or stretch it to much. I do them dry but many like to lube them up. After you get it on let it sit for a few minutes then lube it good and insert it into the cylinder barrel. I've never had one leak, maybe you'll be so lucky! LOL
Ed
Old 10-14-2011   #9
kemptvilleguy
1st Yr. Apprentice
Equipment: LS 2500
Quote:
No I didnt try soaking it (or boiling it) in hydraulic oil but I will try it if thats the key.
Thanks
Old 10-14-2011   #10
kemptvilleguy
1st Yr. Apprentice
Equipment: LS 2500
Quote:
Ed
Ed, I tried putting one in dry but I dont have a seal pick. I used a tiny flat screwdriver but the diameter of the parts of the pison that you have to get by to get it to the centre groove dictate that it must be stretched. When I tried to put it back into the barrel thereafter, it just got mangled up in the threads because it was protruding too much....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
