Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Tractor Operating
Tractor Operating Wondering what that strange lever does, how to safely hill climb or get into 4WD? Discover and share how to get the most out of your tractor.
Reply
Thread Tools Display Modes
Old 09-21-2009   #1
jb62901
2nd Yr. Apprentice
jb62901's Avatar
Default Cab Build
Finished the cab this weekend.
http://tinypic.com/usermedia.php?uo=...GFw4h4l5k2TGxc
__________________
BX2360 LA243 FEL + Tons of Implements Many Homemade.
jb62901 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-22-2009   #2
dusty-t
4th Yr. Apprentice
dusty-t's Avatar
Default Re: Cab Build
Hi jb nice job. I am a firm believer in do it your self stuff. If I can build it I ain't buyin it.
dusty-t is offline   Reply With Quote
Old 09-24-2009   #3
joekimtkd
2nd Yr. Apprentice
joekimtkd's Avatar
Equipment: B7510DT, 4' Snow blower, 4' Loader, 6' Blade, 6' 3PH Finish mower, 6' box blade,
What kind of material have you used on Glass and walls~~???
Walls are look alike some kind of plastic but looks so rigid.
and how did you secured them on the frame?
joekimtkd is offline   Reply With Quote
Old 09-24-2009   #4
jb62901
2nd Yr. Apprentice
jb62901's Avatar
Sides were made from truck tanneau covers, frame is made from aluminum angle. Windows, Duraplex Acrylic
Frame
http://i33.tinypic.com/15374aq.jpg
__________________
Old 09-25-2009   #5
joekimtkd
2nd Yr. Apprentice
joekimtkd's Avatar
Thank you for the reply.
Yes I've seen that aluminum angle iron frame picture.
but what I meant to asking you was that angled aluminum frame goes to actual tractor's frame.
Where did you hook it up to secure the whole cab?
I'm almost done mine too. I'm going to paint tomorrow.
Once I'm done, I'll post it here too. but if I could learn from you something
better idea on the securing onto frame...
Thank you again.
Old 09-25-2009   #6
jb62901
2nd Yr. Apprentice
jb62901's Avatar
joekimtkd; This cab is mounted both to canopy that was in place before the cab build and floorboard and fenders. see pic
floor mount
http://i37.tinypic.com/1izt35.jpg
then angle over fenders for rear upright angle to canopy
http://i33.tinypic.com/29o3nkh.jpg
Hope this helps
__________________
Old 09-25-2009   #7
jb62901
2nd Yr. Apprentice
jb62901's Avatar
Joe also see the front and mid angle uprights to canopy, can't see the rear but it also came off the fender angle to the canopy.
Guess I should of taken more pic
http://i36.tinypic.com/2mdfous.jpg
__________________
Old 09-25-2009   #8
joekimtkd
2nd Yr. Apprentice
joekimtkd's Avatar
I should have seen your cab before I built mine~~~
Well~ some how, I did all the mounts on my idea which I had to squeez
my brain sooooo hard.:
Possibly next week sometime I could post mine though.
Tomorrow, I'm painting. and put all the windows, doors back on.
and final touch for the cabin. and Have to install all the lights for front and
back and inside light. and then have to build some tool box inside of cabin too.
and then I'm going to modify the snow blade to installs onto my bucket.
so I could use snow blade all times as well as bucket for snow removal.
Old 09-25-2009   #9
jb62901
2nd Yr. Apprentice
jb62901's Avatar
Can't wait to see yours, at least you had plans.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
