Dumb question on a post hole digger
Jayhawk238
2004 L5030 HST/CAB
Oct 30, 2010
97
10
Featherville, ID, United States
Hi to all my Orange tractor friends. I have a Grand L5030 and my question is which of the three pin holes for the upper link should I use to get the most height with the lower links in their highest position. :confused:
284 International
B6000 with FEL, assorted Yanmar machines
Mar 25, 2011
151
California, USA
The lowest on the tractor should give you the most elevation at the end of the auger. You will be able to see it instantly when you're fiddling with it. Have fun! (I hate connecting my auger, it's the toughest implement I have to connect)
Jayhawk238
2004 L5030 HST/CAB
Oct 30, 2010
97
10
I agree, it can be a real bi#%h. Attached is a picture of a PHD stand I found on a forum and built. Makes it a lot easier to install or remove it from the tractor.
Thanks for your reply. Hate it when I get those brain farts!!! :D
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
27
Ventura Ca
thanks for sharing the photo of your auger hanger Ill be building one this next weekend looks like a sweet way to go .....Dan
bcbull378
Sep 6, 2011
579
27
Ventura Ca
Thanks again for sharing the picture of your auger stand as you can see from my photo I built one also I can hitch up the auger by myself with no effort at all. When any of you do this make sure when you hang you auger have it on a balance thats the key. Thanks again Dan
2,789
Thats a pretty neat Idea,, bet ya could even hang a buck off that thing
bcbull378
Sep 6, 2011
579
27
Ventura Ca
you can rest assured there will be plenty of buck deer and wild hogs skinned here
