Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Gray Market & Zennoh
Gray Market & Zennoh Own a gray market Kubota? Not sure? Educate yourself and others on these commonly found and popular models.
Reply
Thread Tools Display Modes
Old 09-10-2009   #1
royboy42
1st Yr. Apprentice
royboy42's Avatar
Equipment: L something or nother
Default L1500 oil/fuel/hydro system.
I'm going out on limb here.
The white screw on filter on the left is the fuel filter.
Is the horizontal metal cylinder in the bottom right of the picture the oil filter? Is that just a protective cover for what i think is the oil filter?
The bolt with the little dab of orange on it's head just in front of the clutch pedal.
Is that the check level hole for the hydro fluid?
Is there a filter or screen for the hydro system? If so, where would it be?
I'm getting some squaking/squaling outta what sounds like the pump area when i go to raise an implement. and it's jumpy at times/not very smooth.
Thanks
royboy42 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-11-2009   #2
Service Dept Vic
Service Dept Vic's Avatar
Default Re: L1500 oil/fuel/hydro system.
You are correct on all accounts. Trans level is correct, when it runs out of that hole.
Hydraulic screen is located just below and rearward of the LH footrest. Look for an oval or teardrop shaped plate that can be removed with a couple of 10mm bolts.
Hydraulic screen is tube shaped, and can be withdrawn with a pair of pliers. Use care not to tear it.
Drop all the hydraulic oil before pulling the screen! Replace with new oil after changing the filter.
I get so many requests for where this screen is located, I'm going to take a picture of one of my L-1500's and post it up!
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 09-12-2009   #3
royboy42
1st Yr. Apprentice
royboy42's Avatar
Thanks Vic.
That picture outta do a lot of good.
Old 11-04-2009   #4
hawthd
New Member
Equipment: L2000
Just wondering where you get oil filters for the L1500 oil bath type, And if there is a cross reference to a fram or wix type filter. Thanks
hawthd is offline   Reply With Quote
Old 11-04-2009   #5
osut362
1st Yr. Apprentice
osut362's Avatar
Equipment: M9000dtc, b7500hs
i have one of those 1500s and the oil filter is a wix 57030....al
osut362 is offline   Reply With Quote
Old 11-05-2009   #6
royboy42
1st Yr. Apprentice
royboy42's Avatar
http://www.orangetractortalks.com/20...-part-numbers/
Osut362 is correct. I found one at the local napa store. close to 25 dollars a piece.
I'm looking into buying the block for a L175 and then i'd be able to use the spin on 3 dollar filters.
http://www.orangetractortalks.com/fo...ighlight=l1500
After a couple of oil changes the conversion would pay for it's self.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
