Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 08-06-2011   #1
Jimb21
1st Yr. Apprentice
Equipment: B21
Default Hydraulic line replacement
I have to change out a hydraulic hose on the front bucket of my B21. Do I need to drain the "pressure" out or do I just unbolt the connection and remove?
Thanks
Jimb21 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-06-2011   #2
GWD
4th Yr. Apprentice
GWD's Avatar
Equipment: M7040, L48 TLB, BX2200
Default Re: Hydraulic line replacement
Just move your joystick to all positions and any remaining pressure should be relieved.
Then it is just a matter of disconnecting the old and putting on the new.
__________________
2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
2002 Kubota L48 TLB, 12", 18", 24" HD buckets
2001 Kubota BX2200, Turf, LA211 FEL
7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, 6', 4' flail mowers, 6', 4' rototiller, 6', 4' Bush Hog mowers, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, 8' offset disc, lots of misc.
GWD is offline   Reply With Quote
Old 08-07-2011   #3
Jimb21
1st Yr. Apprentice
Equipment: B21
Thanks for the reply. I will post with results when I replace the lines later this week
Jim
Old 08-07-2011   #4
kuboman
4th Yr. Apprentice
Make sure everything is resting on the ground
kuboman is offline   Reply With Quote
Old 08-07-2011   #5
Bulldog
Master Tech
Bulldog's Avatar
Equipment: M 9000 DTC, L 3000 DT
Just always keep in mind that your hydraulic system is like a loaded gun. There are mechanics killed every year from having high pressure oil being injected in their skin. A hydraulic system is about like working with a bull. It can be done safely but you never want to take it for granted.
__________________
AMSOIL, protect your investment.
Bulldog is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
