Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 07-21-2011   #1
ajhaig
1st Yr. Apprentice
Default Clutch Adjustment B7100
I believe that I need to adjust the clutch on my B7100 (gear drive 460 hours).
I'm getting a slight grinding when I first move the shift lever into any gear, I don't believe that the clutch is slipping in any way.
I've read that I can adjust the clutch, but I do not understand the terms "play" and "travel." What do these terms mean and how can i tell if i'm in the right tolerances (i.e. 2-4 mm play and 8mm travel)?
Assuming that I'm correct, and the clutch isn't slipping, does it sound like the clutch need to be adjusted?
Many thanks.
AJ
ajhaig is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-21-2011   #2
Dennis
1st Yr. Apprentice
Default Re: Clutch Adjustment B7100
Press your clutch pedal down with your hand and you can feel it move with only the resistance of the pedal return spring until the throw out bearing engages with the pressure plate springs : that is free play (2-4mm)
I usually unhook my pedal return spring first, to get a better feel for the resistance when the throwout bearing is just engaging with the pressure plate springs
Continue pressing down, as far as you can, until your pedal adjustment bolt pushes against the tractor body: this distance is the travel. Adjust the bolt so this distance is 8mm
Finally, adjust safety switch bolt gap to 3-4 mm
Test with the tractor running that:
Engine starts (safety switch gap setting is not too small)
Gears can be changed without snicking.
There is not excessive travel that puts unnecessary pressure on the pressure plate . Just enough so gears change ok and tractor isn't moving when you fully depress pedal.
If the latter happens be prepared to quickly throw the gear stick back to neutral or hit the cut off switch.
If adjusting clutch does not resolve the problem then you might need to look at possibility of worn pressure plate springs , worn throwout bearing and/or loose drive shaft cv joint.
Dennis is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
