Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 06-03-2011   #1
Jimb21
1st Yr. Apprentice
Equipment: B21
Default Looking for B21 wiring diagram
My B21 starting smoking under the dash panel and when I removed the panel, the connection between the lights and the wiring harness was singed. A couple of the wire leads on the wiring harness side were corroded through and the copper is showing and not making contacts. The fuse box also had a fuse that was burned. Now the alternator is not charging the battery. The red engine light is now on intermittenly also. I want to get this re-wired or figure out what piece off the wiring harness should be replaced. I am not concerned with getting the lights working again as much as the alternator or most importantly, not smoking under the instument panel again
Thanks,
Jim
Jimb21 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
