Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Thread Tools Display Modes
Old 06-02-2011   #1
New Member
Equipment: Kubota B2400 4WD with front loader
Default B2400 Front Axle Pivot Leak
My front axle is leaking gear oil on my B2400 at the pivot point in the center of the axle. I tore it apart and I found there is an O-Ring that seals the gear oil from leaking out. I have ordered this O-Ring numerous times but the one I get from the dealer is smaller in thickness than the one on my tractor. The front axle has 2410 stamped on it so I was wondering if the axle may have been replaced. I bought the tractor used. There are chrome plated bushings in the axle pivot brackets that have some wear however Kubota does not sell just the bushings. The only way to get them is to buy the whole bracket which is $$$ expensive. Has anyone dealt with this on hear?
ORANGEMAN is offline   Reply With Quote
Sponsored Links
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
