Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 06-02-2011   #1
Pumpkin
New Member
Default RTV 1100 pre-wired?
Hello all,
Does anyone here know if these are pre-wired as part of the factory harness for the front and rear roof/work lighting?
I'm about to order the swicthes and lights and was wondering if it's just a quickie hook up, or if I'll be installing wiring as well.
Thanks,
Chris
Pumpkin is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-02-2011   #2
eserv
Journeyman
eserv's Avatar
Equipment: BX24, A1000 Kubota Generator, Bolens (Iseki) G154 with tiller
Default Re: RTV 1100 pre-wired?
They are prewired for two front lights and a work light on the left side. If you want two work lights you'll need to run a wire across the back to operate the one on the right side. the vehicle wiring and fuses are adequate to run the extra light.
Ed
eserv is offline   Reply With Quote
Old 06-02-2011   #3
Pumpkin
New Member
Thanks Ed!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
