Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Fabrication & Customization
Fabrication & Customization Show off and share the details of your custom improvements to your tractor, your truck or anything else you get your hands on.
Reply
Thread Tools Display Modes
Old 05-27-2011   #1
Reddragon774
1st Yr. Apprentice
Equipment: 97 L3600 GST
Default Homemade Cab & snow plow conversion
Last year my old 4X4 truck died so I made a cab from light gage steel and plywood and put my Meyer snow plow on my L3600 tractor....it has a loader on it so I made my plow carrage fit the loader mounts...I need to find some chains this year to fit my tires.....
Click image for larger version
Name:	Tractor Cab 001sig.jpg
ID:	3549   Click image for larger version
Name:	Tractor Cab 015sig.jpg
ID:	3550   Click image for larger version
Name:	makin the plow mountsig.jpg
ID:	3551   Click image for larger version
Name:	Tractor Cab 011sig.jpg
Reddragon774 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-28-2011   #2
Kytim
4th Yr. Apprentice
Equipment: B6000DT, B7100DT,Snowplow, RM360, Scoop, Cultivator, Carryall,Disk, plow
Default Re: Homemade Cab & snow plow conversion
Good job on the cab... that will make a HUGH difference during the chilly times of the year. the Plow mount looks like one of their factory units. I wish I still had the Meyer plow the I used to have on a 78 1 ton chevy 4x4 dually. It was a good plow and I liked it over other brands i've seen.
kytim
Kytim is offline   Reply With Quote
Old 05-29-2011   #3
firejunkie
1st Yr. Apprentice
firejunkie's Avatar
Equipment: Kubota Mx4700 4w/FEL, Modern Ag cutter,Dirt dog Box blade and Rake, Custom forks
nice work there, did you seal the plywood with anything like fiberglass resin or is it just painted? also the plow looks awesome, very nice fab work there, what are the springs for? (don't work with plows that much).
EDIT: I think I figured it out, are they to absorb shock of the pitch control, to lessen damages to the hydraulic cylinder and mounts?
firejunkie is offline   Reply With Quote
Old 05-29-2011   #4
cmorningstar01
3rd Yr. Apprentice
cmorningstar01's Avatar
Equipment: B7500HSD LA302 FEL FEMA 3 pt Utility platform B5100E 348-7 Mower 46" Snow Plow
Most snow plow setups have springs so that the plow blade can flip down to go over obstacles like curbs and manhole covers , Reduces damage that would be caused by a rigid setup, When an object is struck the top of the blade pivots forward allowing the bottom edge to rise up over the obstruction.
cmorningstar01 is offline   Reply With Quote
Old 06-10-2011   #5
Reddragon774
1st Yr. Apprentice
Thanks....just 2 coats of enamal.....
Old 06-10-2011   #6
Reddragon774
1st Yr. Apprentice
Quote:
kytim
Thanks .... yes makes pushin the snow much more tolerable...LOL
Old 06-11-2011   #7
rayc
1st Yr. Apprentice
rayc's Avatar
Equipment: kubota L4310 hstc
Hey reddragon nice job, how wide is your plow?
rayc is offline   Reply With Quote
Old 06-28-2011   #8
Reddragon774
1st Yr. Apprentice
Quote:
Thanks 8ft.....a tad big for the tractor 71 /2 would have been better and a little lighter but that's what I had.....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
