Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Implements & Attachments
Implements & Attachments Find everything related to operating, servicing and maintaining that loader, mower, blade, snow blower, tiller, hitch or scraper, right here.
Reply
Thread Tools Display Modes
Old 05-24-2011   #1
UWAdventurer
1st Yr. Apprentice
UWAdventurer's Avatar
Equipment: Kubota L3400 w/FEL & Woods 7500 backhoe
Default New to OTT-L3400 3 pt hitch adjustment?
Newbie here-Hi All!
I just purchased a 2004 L3400 with a Woods 7500 backhoe. I want to put my bush hog on, but the linkage on my 3 pt hitch is all rusted up. I am working on getting it loose so I can oput anti sieze on it. Got it all except one end of the top link loose. I need to know how tho adjust the 3PH when I reassemble it. I am afraid of bending or breaking something if I don't get it set at the proper lengths, etc. I can't find any good info on this. I have never installed/adjusted a 3PH before. Any help is greatly appreciated.
Thanks All!
UWAdventurer is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-24-2011   #2
meanjean
4th Yr. Apprentice
meanjean's Avatar
Equipment: Kubota L1801
Default Re: New to OTT-L3400 3 pt hitch adjustment?
Can you post a pic?
meanjean is offline   Reply With Quote
Old 05-25-2011   #3
UWAdventurer
1st Yr. Apprentice
Pics of what? I have my bachoe on my tractor now. I am wanting to remove it and install my 3 pt hitch parts so I can use my bush hog. I need to know how to adjust the linkage on those parts to avoid damage to anything.
Thanks.
Old 05-25-2011   #4
Hook
2nd Yr. Apprentice
Hook's Avatar
Equipment: L3240 with LA514 FEL, Box Blade, Howard Rotovator, All Purpose Plow, Sub Soiler
If I remember correctly the lift arms can only be put on one way. Seems like there is a linkage adjustment on the lift arms but I have never had to change that from the factory setting. One end of the top link can go in any one of 3 positions where it attaches to the tractor. I believe the top hole is the default setting (for lack of a better term). Once you get your mower on the tractor the only adjustment you have is making the top link longer or shorter. Personally, I do not want the top link to be rigid. I would rather it have a little slack. On some mowers, the top link connects to a piece that will swivel. That is the part that needs to have room to move. In other words don't thread the top link as tight as it will go. The L3400 won't pick the mower up as high as you might like or might have been used to with other tractors that are higher off the ground. I usually just get the mower approximately level (or maybe a little lower in the front) with the rear wheel touching the ground and supporting a lot of the mower's weight. I have also had to adjust the mower to the L3400 by raising or lowering the rear mower wheel. I hope I have understood your question and I hope this will help.
Hook is offline   Reply With Quote
Old 05-25-2011   #5
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
YEP Hook has nailed it right on the head!
You want to keep the turn buckles on the lift arms tight so the bush hog wont sway side to side. That'll make ya mad as hell when you take a turn and the bush hog is in the other direction. And like Hook said keep the top link a lil loose to the bush hog will float up and down to a degree.
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Old 05-27-2011   #6
UWAdventurer
1st Yr. Apprentice
Thanks guys that helps.
Old 05-27-2011   #7
stuart
3rd Yr. Apprentice
Equipment: B7001 with loader & tiller, 3 point hitch and 4' rear blade
Send a message via Yahoo to stuart
You may have seen the discussion here
http://www.orangetractortalks.com/fo...ead.php?t=4461
Different tractors but very similar hitch assembly.
stuart is offline   Reply With Quote
Old 06-05-2011   #8
UWAdventurer
1st Yr. Apprentice
Got it on and adjusted. Found a diagram and instructions on my bush hog showing angles and orientation. Originally had the top link too tight.
Thanks for the info all it did help.
Old 06-05-2011   #9
Hook
2nd Yr. Apprentice
Hook's Avatar
Glad to hear you got it set up. Good Luck and welcome to OTT.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
