Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Fabrication & Customization
Fabrication & Customization Show off and share the details of your custom improvements to your tractor, your truck or anything else you get your hands on.
Reply
Thread Tools Display Modes
Old 05-15-2011   #1
grimace
1st Yr. Apprentice
grimace's Avatar
Equipment: L3800 and 12 implements. City boy country toy!
Default Best way to tie down a tractor?
I just had 4 d-rings welded on my tractor so I good spots to attach my straps when I trailer. I hate to use chains! They scratch, They are heavy and slow to hook up.
John
Click image for larger version
ID:	3490   Click image for larger version
ID:	3491   Click image for larger version
Name:	front hooks.jpg
grimace is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-15-2011   #2
IC-Smoke
1st Yr. Apprentice
Equipment: B2400, ZD28, BX24
Default Re: Best way to tie down a tractor?
Nice!!! Just make sure you use the highest rated ratchet straps you can get! The Weight Master around here wouldnt let that fly. Only certified chains and ratchet binders for me!
They have weld on D rings that are higher rated than those bolt on ones:
The ones you used look to be :
Breaking strength: 12000 lbs
Safe working load: 4000 lbs
__________________
BX24 TLB, 54"pro Mower/Bagger
B2400 TL
ZD28 60"Pro
Ford 861 Powermaster (wide front)
Allis Chalmers "G"
1990,2001,2006 Dodge CUMMINS 2500 4x4 std cabs
IC-Smoke is offline   Reply With Quote
Old 05-15-2011   #3
grimace
1st Yr. Apprentice
grimace's Avatar
These are rated at 11000 pounds and are welded on.
And the straps I use are 10000 rated and I dont let them rub on anything.
I dont see how chains and binders are that much better?
The tractor with an implement is about 4200 LB.
If Iam doing this wrong please let know!!
Old 05-15-2011   #4
Bulldog
Master Tech
Bulldog's Avatar
Equipment: M 9000 DTC, L 3000 DT
The laws in each state are different but more than likely chains and binders are required by law, they are in Ga. One chain and binder on each corner are required here and if you have a implement is hooked up it has to be chained also. Most of the time THE MAN won't mess with farm equipment as long as it looks secure and safe. I personally use 2" straps on mine instead of chains.
Tip:
After years of being a heavy equipment operator I have learned this. A dirty truck will get stopped over a clean truck every time. If your truck/trailer is nasty and looks like rolling scrap metal you are giving them a excuse to pull you over. Correct lighting and being clean will make a difference.
__________________
AMSOIL, protect your investment.
Bulldog is offline   Reply With Quote
Old 05-15-2011   #5
Kytim
4th Yr. Apprentice
Equipment: B6000DT, B7100DT,Snowplow, RM360, Scoop, Cultivator, Carryall,Disk, plow
+1
"Tip:
After years of being a heavy equipment operator I have learned this. A dirty truck will get stopped over a clean truck every time. If your truck/trailer is nasty and looks like rolling scrap metal you are giving them a excuse to pull you over. Correct lighting and being clean will make a difference."
Kytim
Kytim is offline   Reply With Quote
Old 05-15-2011   #6
284 International
2nd Yr. Apprentice
Equipment: B6000 with FEL, assorted Yanmar machines
As an observation, not criticism: the third picture shows the ratchet strap running laterally at a pretty steep angle. It might be more convenient to reach, but that strap isn't going to do as much to hold the tractor forward and back as it will left to right. You would do better to move it so it is more in line with the long axis of the tractor.
Bulldog made a great point about presentation being important. If you look like you know what you're doing and run a tight operation, you can get away with a safe but not technically legal setup while others doing the same thing but with messy, untidy or disreputable looking rigs will get stopped. 4 10,000 pound ratchet straps properly secured to good fastening points on that rig is not unsafe, whether or not it's legal. I don't see anything wrong with working around the legal requirements while remaining thoroughly safe with things like this.
I really like the idea of permanent D-rings to quickly and easily secure the tractor. Good job!
284 International is offline   Reply With Quote
Old 05-15-2011   #7
Kytim
4th Yr. Apprentice
While looking at your pic's again, I noticed something. I may just be me but, I really don't think you should have welded the rings onto a certified ROPS. The heat could cause a failure in a roll. Look, I'm not wanting to start an argument just stating the observation about an engineered piece of safety equipment with a stated stress factor.
I really like the idea of permanent locations for tie-downs on both a tractor and its trailer.
Kytim
Rev. Timothy S. Midkiff
Old 05-15-2011   #8
Bulldog
Master Tech
Bulldog's Avatar
Quote:
I'm sure it's safe to say that it's no longer under warranty because of that. It is a handy idea though.
__________________
Old 05-16-2011   #9
grimace
1st Yr. Apprentice
grimace's Avatar
WOW I never even thaught of that the warranty!
Would welding onto the ROPS really weaken it?
Old 05-16-2011   #10
Eddie Jr.
2nd Yr. Apprentice
Eddie Jr.'s Avatar
Equipment: B3200 HSD
Quote:
+1 Here.
I love the idea of the rings. Is there really a better place to put them though? The fact that they are a little higher mounted will certainly help hold the load down too.
M.
__________________
B3200HSD, LA504 FEL, RCK60-27BA MMM
Farm King C72SS rear blade, Bush Hog SBX60 box blade.
Loving life in Orange Country!
Eddie Jr. is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
